Question about Miele Vacuums
My miele medivac will not turn on when plugged in
    Novelist:
  • 97 Answers
It could be either the switch, the motor, or the cord reel. Try plugging it in and slowly feeding the cord in and out while clicking the power switch on and off. If the motor kicks on while doing this, you have an intermittent short in the cord reel.
If you remove the bag chamber lid, (on the s300 series merely opening it until it makes an awful cracking sound, and then lifting it off;) you will be able to access the screws to remove the rear housing. Under the exhaust filter are two screws that will allow you to remove the control unit, and then there are about five screws on the top that will need to be removed if you need to go further.
The control unit contains the switch, which you can test continuity through by using a VOM. If the switch checks out ok, you can test continuity through the other electrical components on the underside of the control unit. If you find a component that does not have continuity, replace it. If they all appear functional, continue with the disassembly:
On the s300 series it is easiest to flip the machine upside-down after removing the top screws, and then lifting the base away from the top housing. This will give you access to the motor and the cord reel.
What can occasionally happen with these cord reels is that they can wear out, allowing too much lateral slop of the actual reel assembly. You can shim this by using something on the axle in the center to push the reel assembly back against the contacts. I use a small rubber "doughnut," but pretty much anything non-conductive will do the trick.
If this doesn't restore electrical continuity, you'll probably need a new cord reel. I highly recommend against trying to do any further repairs on the cord reel itself, as it's a nightmare to deal with... especially if the main spring comes apart.
Any other problems will have to be referred to a repair station, since it could then be either the motor or the motor control board.
Do NOT attempt to test the motor by directly connecting it to wall voltage, as the actual power applied to the motor when it is functioning is stepped down by the circuits attached to it, and attempting to "hotwire" it will fry the motor.
Hope this helps,
-R
Posted on Aug 01, 2008
How do I get the vacuum to turn on now?
Just to cover all bases, have you tried an outlet on another circuit? It sounds as though the vacuum (motor perhaps) shorted and tripped the breaker.
Nov 15, 2017 | Miele Vacuums
Miele power brush switch goes and and off when vacuuming
look for loose or broken plug, try holding the plug at each end to see where the weak spot is.
If the plug isn't the problem, then look for a broken wire.
Dec 13, 2014 | Miele Vacuums
Miele upright vacuum makes loud noise and dust comes out at bottom
It sounds to me like one of the hoses is plugged, probably the one that comes from the brushroll. That would make the dust and dirt come back out the front and would not let the vac pick up like normal. Clear the plug and you're machine should start cleaning better again.
Nov 09, 2013 | Miele Vacuums
Miele revolution 5000 no power light flashing
I would refer to your owner's manual. If the manual has no resolution, then I would contact the manufacturer directly.
May 08, 2012 | Miele Vacuums
It's plugged in but won't turn on?
Let's do some trouble shooting:
With it plugged in, do you see any lights on the control panel?
Miele also has a little device, that let's you 'park' the floor want in a neat little slot at the handle end of the machine-- and when it is plugged in there, the machine shuts off.
Finally there are switches on the top of the machine that control the speed of the machine-- what happens when you operate that switch-
The other switch turns it on and off-- Do you feel the switch snap when you push it?
Let us know what you find--
Mack B
Jan 20, 2011 | Miele S318 Bagged Canister Vacuum
Miele just stopped working?
When a Miele canister just stops working all of a sudden, it's usually a pretty clear indication that either you have a bad cord reel, or a bad switch. I would say that in 60% of Miele repairs that I do with this problem, the cord reel has gone bad.
One easy thing that you can try to see if the cord is bad, is put one hand on the on/off switch, and the other hand grab the cord (making sure it's fully retracted inside the canister). Now pull the cord out slowly with your one hand, while continously turning the switch on / off, on / off. Keep pressing the switch on and off while pulling on the cord. Usually if the cord reel has gone bad, then you may hear the vacuum attempt to start, or even turn on while you're pulling on the cord. The cord reels in Miele use a metal spring inside that makes connection with the rest of the vacuum. Over time this spring will start to loose it's strength, and eventually will get so bad that it no longer makes contact with the rest of the vacuum. By pulling the cord out slowly and pressing the on / off switch, a lot of the times the spring will make connection somewhere, and the motor may turn on temporarily.
If this happens, this indicates your cord reel needs to be replaced. I have done a detailed repair here on Fixya on how to replace the cord on a Miele canister vacuum that you may read here;
http://www.fixya.com/support/t2281026-miele_s514_will_not_come
If you can't get the vacuum to turn on at all, this can only mean a few things. First the cord reels spring is gone completely, and wont make any connection with the rest of the vacuum, and you'll still need to replace it.
It also can mean that just the plug that plugs into the wall is bad, is your plug bent, or no longer straight on either prong?
It can also mean that your motor has gone bad. This however is usually the least likely of all the problems. The Miele motors are almost bullet proof, and typically last 20 years. I can count on one hand the number of Miele motor replacements I've ever done in 10 years of fixing vacuums.
I can try and help you diagnosis this further if my suggestions didn't help you. Please use the clarification request that you see here on this page to ask me a question. Please just let me know what happened when you tested the cord out as I suggested above. I really hope this was helpful to you. If you found this to be helpful, please be sure to rate the repair as helpful to you by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele S318 Bagged Canister Vacuum
Access to the Plug in Cable of Miele White Star Vacuum Cleaner
Problem solved. A guy posted on the internet a step by step explanation including photos of how to open a Miele White Star vacuum to get to the take up reel.
May 13, 2009 | Miele S251i Plus Bagged Canister Vacuum
I'm using Miele Medivac vacuum and I just sucked in a small plastic eye drop container by accident(I sometimes take off the brush part to **** in 'small enough' articles). And it is jammed in the part...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761462
Generic problem for all Vacuums
Posted by greenvanilla on Jul 09, 2008
I'm using Miele Medivac vacuum and I just sucked in a small plastic eye drop container by accident (I sometimes take off the brush part to **** in 'small enough' articles). And it is jammed in the part where the plastic hose connector bends. I think I can take it out if I can just disconnect the long necked plastic hose connector that connects the metal wand part and the hose part. Is it designed to be disconnected or should I not even try it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The long necked plastic hose connector is made to be replaced because they do brake upon occasion and the part is made to come apart. If you need assistance please contact your local vacuum cleaner dealer or to contact the Miele factory to get a owner’s manual to check the trouble shooting guide and or a schematic of the breakdown of how to un-install the
long necked plastic hose connector or gooseneck of which some people call it. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/
Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Miele Solaris Electro Plus will not turn on
I was using my Miele Solaris Turbo plus to **** the air off the Space Bag. Now I have the red indicator on and the vacuum cleaner won't turn on. Please help. This is my favorite vacuum cleaner!
May 17, 2008 | Miele S514 Solaris Electro Plus Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
166 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
