Computers & Internet Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have itel p3 compaq pro en pc icanot usig usb device its showing there is no hispeed usb hos controller how can i solve this problum
Anonymous
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Mar 05, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
18994
Points
336
Download a program called Speccy
find out the brand and model number of the motherboard you have and then google them
you should find some basic motherboard drivers for your model
make sure you download a version relavent to the specific Operating System you have installed (Windows 7, Vista, Win XP, Linux etc)
What exe do I need for multimedia controller, USB controller and video controller for a d51c compaq.com evo
What windows do u use? Win XP SP3 will probably fix the problem, or if u can find device driver for your usb media controler that will solve that will solve the problem
2answers
Can a compaq fs7600 connect to a wireless internet or is it too old?
The monitor is just a display device, it how fast your PC is. I can easily surf the web for simple email and browsing the net with P3 1.GHz machine running XP PRO. You will need WIFI card for the PC.
1helpful
2answers
Vestax vcm 100 driver traktor pro
hi, you need to go here:
http://help.vestax.co.jp/en/detail.php?id=80&id_page_url=56&cate=0
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
2answers
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
System driver problem
load WinXP professional on your computer, and this will solve your driver problem. good luck
1helpful
My nokia 6500 slide is not detected on my p3 processor computer
hi ,
on your p3 laptop/desktop go to the device manager and update usb drives (DO NOT CONNECT your phone). Before that uninstall pc suite. Then reinstall again.And follow the on screen guide how to connect the phone.
Intel pro nic no i/o resources
Its simple try this card on some other if u get the same error replace the card
3answers
LOST MY AUDIO DEVICE MANGER
Please specify the Motherbaord version
Anyways if it is Realtek (Most motherboards do have realtek only) you can download the latest version of realtek drivers from
http://www.realtek.com.tw/
2helpful
5answers
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Problems with usb 2.0 hispeed enabled (also fullspeed)
What happens is you don't enable hispeed but leave 2.0 on?
Grand Canyon Tech
Grand Canyon Tech
