Question about Toshiba 32A33 32" TV
Toshiba TV/DVD combo = Model #MD20F51
We have two of these models. I turned them both off on Saturday and now neither one of the units will power on. All the other televisions in the home work. Is there a reset on this model?
  • Darren Rysedorph Oct 24, 2008
    lost power (similar to turning it off?) - now it wont turn back on - i was on a high end APC surge suppressor / battery backup too. wierd.
    any ideas?
    Darren
  • 525 Answers
I don't understand what happen to you. Try to explain very well.
Posted on Oct 20, 2008
Toshiba TV DVD player wont read disc
The player maechanism may have become defective.
Aug 08, 2014 | Toshiba MD20F51 20 in. TV/DVD Combo
How to remove text display on TV screen
I have an older standard Fisher TV, model no. PC1527. The text displays that state, "NEED SETUP PRESS SETUP KEY". I press it and nothing happens. What am I doing wrong. Please help, I want to remove this and other displays like the mute and sound lettering.
Apr 10, 2009 | Toshiba MD20F51 20 in. TV/DVD Combo
Tv Screen Turns blue occassionally while running Toshiba DVD player
If the flashing is regardless of source, the CRT could be at fault. H to K short. ( heater to cathode)
Jul 23, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Tv wont turn on.
try cutting power off and wait 15 to 20 minutes. also try another outlet depending how much power u r pulling thru the outlet u had it in. Had same problem and customer service said unplug for 3 min....not long enuf...so try 15 to 20 min and plug back in.
Apr 10, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Power problem
A common failure in these units is Q401, Toshiba p/n# Bz510004 is a 2SA1624 (HV amplifier) which finally fails due to a resistor R408 Toshiba p/n# Bz210285 a .47 ohm/1w metal oxide having changed in value and at last opening...
This isn't an expensive repair for a qualified shop - but I would suggest not continuing to test your shutdown circuit. What's happening is that HV (high Voltage) is builds beyond tolerances and the shutdown circuit turns your unit off to keep from causing any severe damage. If it failed you could likely burn out the SMPS or cause some substantial damage..
Good Luck!
Bill
Dec 01, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
I'd like to add another on the power problem
Good Luck!
Bill
Nov 10, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba TV/DVD combo turns on then off again.
try letting it sit for 15-20 minutes unplugged from the wall and maybe try another outlet depending on if u got plugged in to a power strip, possibly pulling to much power from that perticular outlet.
Oct 16, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
BASE tv/dvd combo- not toshiba but it looks like this model
Same thing happened with us, the onscreen display button unlocks the tv, goodluck
Apr 03, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba 32A33 32" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
