H P Photosmart C4180 All-in-One Printer - Scanner - Copier--no go.
Slow running - 15minutes + to print a Self Test Report
Display says I am using the wrong type of cartridge - I use 343 as described on the back of users handbook and have been doing so for some months without any problem.
  • Ashgate Aug 02, 2008
    display still insists that 343 is the wrong cartridge for this machine
    pressing any button, and will not operate with or without a tricolour cartridge in place.
    no reaction to any button inc. setup,
  • Ashgate Aug 06, 2008
    New colour cartridge fitted....good as new.
    Many thanks for your assistance
HP Photosmart C4180 All-in-One Printer catridge door open signal on product
Posted on Nov 09, 2008
Try looking under the cartridge I found a big wad of ink? almost like a piece of chewing gum in the area under the cartridge. Took it out cleaned the area problem solved.
Posted on Oct 29, 2008
    Genius:
  • 3,422 Answers
Go to the printer SETUP button. Select the TOOLS option, then pressed OK. First, select the CLEAN PRINT CARTRIDGES option. Wait until it finishes. Second, select the ALIGN PRINT CARTRIDGES, under same TOOLS menu.Wait until this finishes and let me know if this cleared the wrong message.
Posted on Jul 30, 2008
  • 1 more comment
  • Priya darshan Jul 30, 2008
    Also make sure that the cartridges are installed correctly.I mean check if they are properly seated.
    If you are absolutely sure that cartridge is installed correctly, the
    contacts where cartridge may be dirty. Clean gently with soft lint free
    cloth and retry.
  • Priya darshan Aug 02, 2008
    ok,give this a try replace your old cartridge once and see if you get that same error.If you don't then remove the cartridge and replace this again.
    Let me know the result..
How do i fix a cartridge jam?
Hi andmary,
While using the HP Photosmart C4180, the printer may display error messages. These messages alert you, as the printer's user, to any problems affecting the printer's performance. The printer can display the message "Carriage Blocked" on the printer's display screen, stopping any current print jobs and preventing you from printing anything until you resolve the problem. The error message can be caused by an actual obstruction, such as a stuck piece of paper, keeping the cartridge carriage from moving freely inside the printer. Sometimes the error is a result of a software error.
Instructions:
1. Turn off the printer, wait 15 seconds, then turn it back on. Press the "Setup" button on the control panel, then use the arrows to highlight "Print Report" and press the "Ok" button to print a self-test page.
2. Remove all the loose paper from the printer's input tray. Turn off the printer and open the back door by depressing the tab on the left side.
3. Pull out any stuck paper, being sure to turn the rollers to check for small pieces of paper. Close the back door and open the printer's front door.
4. Remove any stuck paper from the printer. Move the cartridge carriage from the left to the right side of the machine, removing anything that stops the carriage's movement.
5. Push down on each cartridge, then pull each one out of its slot. Replace the cartridges in their slots, then push forward on them until they each click into place.
6. Plug the printer back in and turn it on, then unplug the printer's power cord from the back of the machine and the electrical outlet. After at least 15 seconds, plug the power cord back in and turn the printer back on. If the problem persists, take the printer to a repair shop.
Hope this helps.
Thank you for using Fixya!
Sep 24, 2011 | HP Photosmart C4280 Aio Printer
HP Photosmart C4180 message "Scanner
Try resetting the printer:
Reset the printer
-Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
-Open the cover of the printer and remove the print cartridges.
-Close the cover and wait for the Insert Ink Cartridges message.
-Disconnect the power cord from the back of the printer and wait for one minute.
-Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
-Open the cover and reinsert the print cartridges.
-Close the cover. If prompted, print a calibration page.
-Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps!
Feb 07, 2011 | HP Photosmart C4180 All-In-One InkJet...
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
PAPER JAM WITH NO PAPER
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
May 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
Photo printing
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
This report provides useful information about your print cartridges, including status information. If the self-test report shows a problem, clean the print cartridges.
Feb 10, 2008 | HP Photosmart C3180 All-In-One InkJet...
Bad Printer Head, Change Magenta (Square)
YOU A HAVE A 2 IN 1. ONCE A COPIER IS 2 IN 1 OR 3 IN 1,( I MEAN PRINTER, SCANNER, COPIER THATS 3 IN 1) AND ONE THIS THING IS DEFFECTIVE ALL OF THEM IS DEFFECTIVE...
Mar 06, 2007 | HP 610 Color Copier
321 people viewed this question
k24674
