Question about Microsoft Wireless Optical Mouse
Wireless mouse Microsoft wireless mouse 3000 suddenly does not work. The receiver is recognized by my laptop and the mouse shows red beam with new battery but does not work. Can an optical wireless mouse go bad after one year?
  • mushmouse Oct 18, 2008
    Mouse suddenly stopped working without cause. Light on bottom is lit and 'connect' button depressed. Any info. would be appeciated. Thank you!
  • Anonymous Oct 24, 2008
    Mouse suddenly stopped working properly. Light on bottom is lit
    and 'connect' button depressed. It is hit or miss - sometimes it will move, sometimes not, and the left click does not always connect.
My mouse would not work (no light) and I fixed the problem be depressing the little tab located on the bottom of the mouse. On the inside left side of the bottom of the mouse where the USB connector rests is a thin tab that turns off the mouse when the USB connector is in place. Try depressing this a few times. My tab had a tendency to stick.
Posted on Sep 01, 2008
Dear friend,
I think that you are right, please check the manufacturing date of the mouse if one year has been passed that means it is ture.please also try to check your mouse after changing all the batteries of your wireless mouse.
thanks.
Posted on Aug 12, 2008
Microsoft Wireless Mobile Mouse 3000 can't connect!!
well doae the mouse run on batteris if thas the case then you just new batteris
Feb 15, 2010 | Microsoft Wireless Mobile Mouse 3000
The red laser pointer underneath the mouse isn't coming on? put new batteries in and the receiver is showing the green light once plugged into my laptop.
I doubt the problem is the battery. I have this same mouse and it has worked beautifully for two years now EXCEPT for one problem: most of the time, the mouse does not turn on when the receiver is removed from the receptacle on the bottom of the mouse. There is a tiny little switch built into that receptacle, along the side wall of the receptacle not far from the light. I have to wiggle this little switch (gently!) by hand a few times until the light comes on. From that point, the mouse will work fine until the receiver is placed back in the receptacle.
Dec 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
I just dropped my mouse by accident and it doesn't work now. How do I fix this?
open up the door to make sure the batteries are okay, reseat the batteries into the slots to make sure the batteries are making proper contact.
If that doesn't work, then try new batteries just to be sure the batteries aren't the issue.
If it still doesn't work then leave the new batteries in and the usb adapter that comes with that mouse, hook it back up to the usb slot on the laptop and see if windows recognizes the mouse. If no messages come up then go into the device manager and see if the mouse shows up in there.
It will show up as either the type of mouse you have or a yellow question mark which would mean you need to reinstall the software for the mouse.
if nothing shows up in the device manager for the mouse then that means the mouse is bad and would need to be replaced.
Dec 01, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless Mobile Mouse 3000 not working
I suggest you do the following. After having synchronized both connecting buttons in mouse and receiver, take off battery and next look for a tiny thin button that protrudes from one of the sides where the receiver is placed in mouse, hold it depressed and put back a new and fresh battery releasing simultaneously this button. Mouse would work correctly. Good luck!!! Chawah.
Aug 03, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless Mouse Doesn't work
You need a new one.
Don't waste your time.
Jun 19, 2009 | Impression Products Impression M1 Wireless...
Microsoft wireless mouse 3000 - all lights are on; flash upon reset, but still doesn't work. Running Vista 64-bit.
Try to take off battery and next push and hold down the small button that protrudes where the receiver is placed in the mouse, put back battery and simultaneusly release the button,it might make the mouse operate correctly. Good luck!!!! Chawah.
May 28, 2009 | Microsoft Wireless Notebook Optical Mouse...
My microsoft model no 3000 wireless notebook is not working.
I suggest to put a new battery in it's compartment and simultaneously to press down and release the small button that protrudes where the receiver is placed at the bottom of mouse. Prior to this procedure the receiver has to be installed in the USB port. Both actions are to be performed at the same time. Cursor will start moving again.
Good luck!!!
Chawah.
Mar 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless mouse not functioning
If I rap the mouse on the desk a couple of times, it then works.
Sort of like Fonzi.
Jul 29, 2008 | Microsoft Wireless Notebook Optical Mouse...
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Optical Mouse Logo
446 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
