I have disconected my computer and now i dont no where my leads go for my key board
Got my husband to do it
Posted on Jul 31, 2008
Hi j have 2005 KIA Sedona the battery w flat due to the rear door not closed properly tried to bump start and jump start still won't start there is no immo light or glow plug light on just keep on...
try disconecting battery and use a charging system to the power leads not to the battery as the battery sounds like itd draining too much once you get the kia started connect the battery carefully leave running with as meny items running but if u have central locking dont leave keys in car
Jan 02, 2014 | Cars & Trucks
Where is the security box on 1993 gran cherokee located
Security Alarm Module is located in rigt side box of glove box (attached image) from Repair Manual (Wiring Section).
Hope helps.
Mar 22, 2012 | 1993 Jeep Grand Cherokee
Solid green light until power button turned on the light goes out disconected power supply from mother board and everything else and plugged it in nothin happens is it dead Jim
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
dont forget to vote
Feb 02, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
How do I reset the service sensors to shut off the messages on the dash board on a 2001 Cadillac Eldorado?
you could try to take the negative cable off and turn the key on to discharge any voltage and put it back on, but be careful,cause on some newer models, if the batt. is disconected, it might lock up the radio and you would have to put in a code. some anti-=theft measure.
but if that dont work, you might have to take it to a dealer
Nov 07, 2010 | 2001 Cadillac Eldorado
When I dont use the computer my mouse are still on, will it ever disconnect?
When you shutdown the computer, there is still power going through the usb and other ports.
If you want to completely switch off, turn the socket off or disconect the power lead.
Aug 03, 2010 | Logitech Cordless Desktop Ex100
How to take of steering wheel in audi 80
First you have to disarm SRS system.How- ensure ignition switched OFF.Remove ign.key.Disconect battery earth lead and make sure accidental reconection is not possible.Disconect power suply multi-plug/red/,located behing driver.s storige compartment under fascia.No waiting time required. Now you have to remove driver.s airbag.There is two screws with 5mm allan/hexagon/head behing an airbag.Open it.Disconect and remove airbag.Use 24 socket for steering wheel nut. When remove a steering wheel be very carefull with spiral cable behing.GOOD LUCK !!! There is tightening torque for steering wheel nut-40Nm and two screws-6Nm.
Apr 24, 2010 | 1991 Audi 80
Key coad light on but immobilizer light comeing off car turns but dont start
try reseting the computer by disconecting the batery wait 2 minutes then try again with the key
if this fails call the dealer and get the visa out
Aug 03, 2009 | 2000 Alfa Romeo 156
Disconect everthing need help
if you look at each plug it should have 2 letters printed on it in black. the proper plugs on the circuit boards have matching letters. this should help you out at least a bit
Apr 07, 2009 | Mitsubishi WS-65813 65" Rear Projection...
Philips x55p laptop h12y
Just done it myself there are little black lugs which secure the keyboard in place.
Look down on the key board and you will see them at the top edge and sides (above keys esc&F1,F5&F6 and so on), just push them in and the key board will pop out.
Anyone know where I can get a motherboard for this machine?
Nov 14, 2007 | Audio Players & Recorders
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
