Question about GE A730 Digital Camera
NAVIGATION PAD WHEN I WANT TO GET CLOSEUP AND TRY TO PRESS THE BUTTON IT WON'T. IT'S SEEMS STICK. IS THERE A WAY I CAN GET IT FIX
  • 153 Answers
Yes, call 800 730 6597 and if it is still in warranty we will replace the nav wheel for you.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Posted on Oct 28, 2008
How do i get my phone to send pic messages it just says invalid destination address every time i try to send a pic message?
This is from the following link: http://www.verizonwireless.com/support/knowledge-base-83298/To
Take and Send a Picture via Messaging.
  1. From the main screen, navigate: MENU > Media Center > Picture & Video.
    Utilize the 5-way navigation pad to highlight and the center button to select.
  2. Select My Pictures.
  3. Select a picture then press the right Soft key to choose Options.
  4. Select Send.
  5. Select Picture Message.
  6. Enter the 10-digit mobile phone number or email address then select OK.
  7. Select SEND.
To send an existing picture this is from the following link:
Send an Existing Picture via Messaging Samsung Convoy Convoy 2
Send an Existing Picture via Messaging - Samsung Convoyā„¢/ Convoyā„¢ 2
  3. Select the picture then press the right Soft key to select Options.
  4. Select Send.
  7. Select SEND.
Mar 03, 2016 | Samsung Convoy Cell Phone
My LG VX 8550 phone was not working properly so i brouth it into the Verizon store and they replaced it with a new one. My music is downloaded on the memeory card which was placed in th enew phone which is...
may be files in the memory card are corrupted or the software which is needed to play the format is not installed ...
if that software is installed then there may be some firmware problem ....
try giving the restore factory settings once if there is any firmware problem it will be solved
Jul 01, 2008 | Cell Phones
Htc ozone (xv6175) will not boot stuck on windows6 1 screen . I removed the battery and held the power button down 30 seconds now it has a message that says- The device is unable to boot because either...
Obviously one of your applications that you installed is the problem. Your best bet is to try to hard reset or reflash your device.
To do a hard reset:
  1. From the Today screen, press the left soft key to choose Start.
  2. Select System Tools then press the center of the 5-way navigation pad.
  3. Select Clear Storage then press the center of the 5-way navigation pad.
  4. Select Factory Default. Enter 1234 then press the left soft key to choose YES.
May 01, 2011 | HTC Ozone XV6175 Cell Phone
My nokia 2730 screen is broken and have put sim card in another phone but no contacts.How do i copy numbers to sim on broken screen when i cant see menu? Neil
Not a problem friend. Just be patience. 1. Just press you end button(i.e your red button) 2. to check weather key pad unlock or not for that just dial any number and press call button, if success then press red button. 3. press menu button, and take the help of your manual book which comes with your phone. 4. see where exact the contact option is and go to that using your navigation key and press ok button (it all will be in imagination as your screen not showing any things)
5. using your navigation key come down to option copy contact, and do the same as manual book show hope it will work for you. As it a hectic job but sure it will help you out.
Thanks
Apr 16, 2011 | Nokia 2730 Cell Phone
Amana ap077r one button on remote doesnt work, how can i fix, i can press all the buttons on the remote and they work except the down button. do i need a new remote or is there an easy fix to this problem.
You can fix the problem of the failure of the contact within your remote. First of all you need to understand that there is CARBON contact underneath the pad that you press. Carefully remove the remote control, use a sharp knife to carefully open without damaging. Take the pad and the remote control PCB out of the cover. carefully using a good cloth clean the PCB and the carbon dots under the pad. if you happen to see any maiture/ sweat tugged inside, use a hair dryer to slowly heat up to remove and dry. Now identify the defective pad. You can get to buy the carbon dots but if have any old calculators/ remote that is lying arround, carefull cut off the carbon dot and using a good glue stick it to the problem pad. If your PCB tracks are intact and if the Remotecontroller IC is alright then you have rectifed the fault. Hope my advice helps.Good day
Jul 08, 2010 | Amana AP077R Portable Air Conditioner
The screen is stuck on the align screen i reset the phone and attempted to reload windows mobile and when the align screen came up i tapped it but it wont go away
Did you perform a hard reset? To do this:
  1. Slide open the device to expose the QWERTY keyboard.
  2. Press and hold the center of the 5-way navigation pad.
  3. While holding the center of the 5-way navigation pad, use the stylus to gently press and release the reset button.
  4. When Clearing Data... appears on the screen, release the center of the 5-way navigation pad.
  5. When prompted, tap the screen to setup the device.
Sep 07, 2009 | Samsung SCH-i760 Smartphone
The Navigation up and right button stops working. please give a advice.
one rubber pad or studs is there under the navigation you r using keypad somany times no thats way that rubber pad loose that strenth, or that rubber pad move little bit side of the coorct position, so you remove your phone panel and re insert that pad.
Jan 24, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Erasing protected pics - Sony Cybershot dcs w-55
Formatting will erase all pictures, including protected images.
  1. Turn on the camera
  2. Press the menu button
  3. Press the "right" pad control button
  4. Then press the "down" to go to Setup (looks like a toolbox) then press "right" again
  5. Then arrow down to the Internal Memory Tool and choose Format by pressing the Center Control Button in the middle of the Control Pad.
  6. or, if you have a memory stick where the image is, select memory Stick Tool and choose Format by pressing the Center Control Button in the middle of the Control Pad.
Hope this helps, if it does, please select FixYa! ThankYa!
Dec 05, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
GE A730 Digital Camera Logo
19 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
