Sony PlayStation Portable (PSP) Console Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My problem is, my psp games is not working - Sony PlayStation Portable (PSP) Console
Ginko
Level 3:
  • Sony Master 19,396 Answers
  • Posted on Mar 05, 2011
Ginko
Sony Master
Level 3:
Answers
19396
Questions
25
Helped
8076879
Points
55462
Hi.
If this happens only with one game. Then the game is defective.
If the PS cannot play any game, then try resetting the PS.See: How to Hard Reset Your PSPGet back to me if the reset does not work.
Regards.
Ginko.
4helpful
2answers
How to download a games and install to psp??
to download a game for the psp
- search for game using bittorrent or any downloading software
- download the game
- save the game on the computer or on a harddrive
to install the game on the psp
- connect the psp to a computer via USB or insert the memory stick on a card reader
- copy the game file from the harddrive to the psp memory card or memory stick pro
- disconnect the psp and try to play the game
note: make sure that the psp is upto date with the firmware because not all games will work right away
if its a PSP GO you just need to go online via WiFi on your PSP GO
- go the sony or psp store then purchase the game download it and save it
How yo download psp games
First, you have to find the game you want, and download it to your computer.
  1. 1 Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  2. 2 To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  3. 3 Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  4. 4 Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
Hopefully, this works for you!
2helpful
2answers
How do i download free psp go games
Like many others who had purchased original PSP games from the retail outlets, you will realize that as the games is completed, buying new games seem to be getting expensive and unaffordable. What else can I do if I want to continue to play new or old fashioned games on my PSP console? I start search and looking for website that offers free PSP download games.
Once I had downloaded the PSP games onto my console, how to play PSP download games was my next question. I'm not sure exactly how PSP works when I download new PSP games onto the unit, but I sure have found some answers while I was looking for it. Since I'm facing and struggling with this problem on how to play PSP download games on my unit, lots of other people must be also getting the same problem.
Hope that I get this right for everyone to play PSP download games because I used the same method here to play on my console. Before we get started, I'm using a PSP unit with firmware of 1.5 and having a Sony PSP compatible memory stick pro duo.
Since you are going to download the PSP games, you must download the games for the correct version of firmware, if not it will not work. Newer version of the firmware is available to anyone from the PSP official website. Most homebrew PSP games works with firmware 1.5 and below because the newer firmware upgrade is trying to block people from using homebrew games. Make sure the games you are downloading ends with PSP because only PSP files are compatible with Sony PSP unit.
instruction
  • Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  • To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  • Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  • Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
  • 0helpful
    Psp games intalling problem
    5.00 m33-4 is a very old custom firmware and all the new games wont work. you need to upgrade to gen-d2 or higher.
    4answers
    How to install games on psp 5.00 m33-4?
    get a game umd
    insert it in the psp
    it will autorun
    play the game.
    OR
    if u wanna play games saved on a memory card, then change the firmware to a custom one for ur psp to get those games working
    2helpful
    How to download games to put into PSP?
    go to this site www.pspiso.com you can download games there and some forum or you can use google to search for a psp game or on multiply.com . after downloading game if you download an .iISO or .CSO put it on iso folder on psp ROOT sample e:\iso is your psp drive for PSX game put it on the GAME folder of your psp sample e:\PSP\GAME e: is your psp drive. IMPORTANT! REMINDER: Your PSP must be Custom Firmware to work the game you download NOT the OFFICIAL FIRMWARE ON SONY PSP OOFFICIAL SITE OR UPDATE ON PSP . Thanks hope it could help you out ^_^
    Free PSP games
    The only way to get downloaded PSP games to work is to have custom firmware. Custom Firmware also dont brick your PSP unless you interrupt your PSP while upgrading your PSP.
    Iso games not runing in my psp
    maybe because you're owning a psp 3000, psp3000 doesn't read iso games only eboots, but sadly eboot games are only demo games. try to consider using a umd to play.
    5helpful
    2answers
    Psp games
    The closest thing you will get to free games are flash games that will work in your psp browser. They are not very good, usually. The are too many sites to list. Just do a google search for 'psp flash games'.
    3answers
    How to put games in a psp memory card?
    inside the memory ..... in the game or iso folder
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
