Question about Microsoft Xbox 360 Console
Red light when i turn on the xbox 360 a red light comes on and a e74 pop on the screen with multi languages
  • jlrochk
    jlrochk May 11, 2010
    I've had the same thing happen to me a few times. I just turn off the xbox and turn it back on. If ONE RED LIGHT comes on just turn the xbox off and then back on and it should work. If there are THREE RED LIGHTS or FOUR something may be wrong with the xbox and you might have to take it in to be looked at. If you need anything else just ask. Hope this helps.
I have tried this one my other console and the a/v cable works perfectly
Posted on Aug 01, 2008
This might be a problem with the AV cable try using a different AV cable and see if that is it
The forth player icon on the xbox 360 is flashing red
Xbox 360 Red Ring of Death Fix Kit
The e74 is an overheat issue. It's also know as the red ring of death (rrod). It is very, very common. The link above covers the entire disassemble and re-assemble of an xbox.. That is if you chose to go that route to repair.
If you have a local Gamestop, they may be able to repair it for a fee.
Jan 06, 2014 | Microsoft Xbox 360 Console
My xbox360 has an air message e74 and has one red light on can I fix it
Your console displays the following error message in multiple languages on your television screen or monitor? E74. System Error. Contact Xbox Customer Support. This is caused by a hardware failure. 1. Turn off the console 2. Turn on the console 3. Verify that your getting this error message If you do get this error message you will need to submit a Console Repair Request at: http://www.xbox.com/support/contact I'm sorry to hear this happend, and I am sorry there is nothing else I can tell you, this happend to me and i got my xbox 360 shipped out in 1-day and back in 3-days. Please don't forget to rate, Thanks!
Oct 07, 2010 | Microsoft Xbox 360 Console
The on button of my xbox 360 turned red and now it wont turn on
hi bro
first see how much red lights are shown on your xbox and on witch corner.9it may b 1 or 2 0r 3 or 4)
and what is on your display screen ?
some kind of error in different languages.named e73, E74 or what else
eXX etc.
then told us.after that we can tell you solution.ok
my email is azibajwa@yahoo.com
May 15, 2010 | Microsoft Xbox 360 Elite Console - Black
It has an error e 74
E74 means a hardware malfunction, might be due to a bad memory storage deive attached to the Xbox 360 which is the hard drive (HDD). Steps to do:
• turn of the console and remove the HDD
• restart the console without HDD
• if it works without the E74 error, the HDD is bad and needs replacement
• if still having the same error even without the HDD, it's is an internal hardware failure inside the sytem already
If all else fails, please contact Microsoft Xbox Support for it ti be repaired. Hope this helps.. Cheers!
May 11, 2010 | Microsoft Xbox 360 Console
Got on red light,E74
An E74 error is when the lower-right quadrant of the ring piece indicator flashes red and displays an error message in multiple languages: "E74 System Error. Contact Xbox Customer Support". The error is caused when there's a video problem with the Xbox's hardware scaler chip being damaged. As of April 14, 2009, the E74 error is now covered by the three-year extended warranty.
Aug 09, 2009 | Microsoft Xbox 360 Console
The flashing red light comes on with message E74
you are seeing one red light on the powerbutton and E74 on the screen?
E74 can only be caused by either the HDD or the console itself,so you might wanna try using a different HDD with your console, if the issue still persists, then most probably, the console is having a hardware failure,there is a possibility that the HDD PORT is not properly woking w/c is causing the e74 error.
if thats the case, try calling xbox support hotline(1-800-4-MYXBOX) to process a repair for the console,it will be free,because Microsoft is extending the warranty of the consoles for 3yrs from the date of purchase for e74 and 3red light issues.
or you can also process a repair online,that is available at service.xbox.com,just click on "repair my console"
hope i'll help you..:-)
May 17, 2009 | Microsoft Halo 3 for Xbox 360
I was playing my 360 for a couple of hours....went to sleep for about 10 more hours....(360 is set to auto power off) turned it on today....i get 1 red ring (lower right corner) an messages in different...
E74 is the error code, call xbox (1800-4MY-XBOX) and inform them of this error.
If you have voided your warranty, you will have to resort to buying a new 360 or a new motherboard.
Dec 31, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
1 red light turns on when going to play it
The cause of E-74 with one red light Error might be overheating of your console and foravoiding such error in future you need to put your machine at an openspace. Ensure that it is placed near the window or you can also makesome external arrangement for cooling of console such as cooling themachine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Eitheryou can send your Xbox to Microsoft (Please note that microsoft is nolonger providing extended warranty for E74 with one red lightError) and wait for 3-4weeks. If you don't want to wait for a month, you can also fix E74 with one red lightproblem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Jun 30, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
