Standard Windows taskbar battery icon does not display
  • Cooper1nc Jul 30, 2008
    standard Windows taskbar battery icon will not display in startup menu or stay after I reboot. Whats the deal?
  • rbasha Dec 01, 2008
    The battery power icon does not show in the task bar even if I have the "Always show icon on the taskbar" checkbox ON in Power Options in control panel. Nothing has helped so far.
Googled Battery meter at startup and followed instructions
Posted on Jul 31, 2008
How Do I Safely Remove Hardware
First off, some of those icons will never be removed, as they are necessary to be there for verification purposes. Safely Remove Hardware is one of them. Any time you plug in a device such as a flash card or external hard drive, devices that read and write data, they show up in this block. Since Windows does delayed writes to save time,l if you simply unplug these devices without letting Windows close out the write cache may cause corrupted files. Right clicking on the Safely Remove Hardware icon will cause a listing of attached devices to be displayed. Clicking on the device you want to remove (unplug) will tell Windows to close out the file cache and dismount the device. Windows will do this and them notify you that the device is safe to remove.
Now, regarding all those other icons that appear,such as OneDrive, volume control, and others, if you don't want them showing up in the taskbar, you can right click on the "^" caret symbol that expands the taskbar, then choose SETTINGS. This will bring up the taskbar settings menu. Scroll down the page to where is says "Select which icons appear on the taskbar" and select that. You will see a long list of possible taskbar icons. Turn off the ones you don't want to see display on the taskbar. This does not remove them from the system, but they will no longer display on the taskbar,
Aug 15, 2016 | Computers & Internet
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
My dell volume icon is deleted
By default, the Volume icon is not displayed when you initially install Windows XP on your system.
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
Thanks, Hope this Helps
Please Rate;)
Gary
Jul 30, 2013 | Microsoft Windows XP Professional
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
Sound not comeing at the takbar speak not show
Show the volume icon in the taskbarIf you end up finding to impractical notification area to have the speaker icon displayed inside the taskbar, you can tell Windows 7 to resume showing the volume, same steps as before:
  • Click on the start menu, and type "volume"
  • Select the Volume's dropdown menu, and change its value from "Off" back to "On"
  • Click OK to confirm and close the Control Panel
Windows 7 has now resumed displaying the volume icon in the taskbar!
Else IF windows XP
goto control panel click sound and audio device then check Place volume icon in the taskbar.
Aug 15, 2011 | Computers & Internet
My icon for the battery power monitor has dissapeared from my taskbar can you help me get it back please
Do you have Windows 7? If so, you can right-click on the bottom right corner of your desktop (try right-clicking the time/date), where the icons for volume control, wireless, battery, etc... should be and select Properties. You should then see a screen where you can turn on/off the icons/notifications for battery power (sometimes my volume control disappears and i have to do this.
Otherwise you can go here, Control Panel\All Control Panel Items\Notification Area Icons and you should find the same thing. Then just turn on your battery power icon/notifications.
Hope this helps.
May 22, 2011 | Acer Computers & Internet
How can i return my volume icon in my taskbar...
By default, the Volume icon is not displayed when you initially install Windows XP on your system. To Display The Volume Icon follow the steps given below: -
4. Click OK.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 13, 2010 | Computers & Internet
Unable to display battery charge on taskbar
Select power management from control panel. there u will be able to turn it on.
Cheers.
Sep 05, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Laptop does not finish booting up
i recommend you need to re-installed the OS
Mar 12, 2009 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
