Question about Panasonic DP-C264 Copier
How can I get a borderless page to print?
Dear Staff of Gurus,
This Panasonic printer DP-C264 is great in many ways, but where's the setting to print borderless? Their literature even shows pictures bleeding off the edge of the sheet, but I can't find the setting. Thanks for checking.
Sincerely, Shandor
  • Shandor Jul 30, 2008
    You're right; it's a laser ptr so we'll have to use inkjet or large plotter and trim down...might use inkjet at Kinko's...
  • Panasonic Master
  • 2,794 Answers
I doubt your going to be able to get it to completely bleed because the copier needs to grab the paper to the next section. Usually the fuser section needs about an 1/8 ". The best way to get it to bleed is to use an inkjet printer.
I work on several copier lines and have never found a bleed control. The best thing to do is put a picture on there that can be expanded to 8 1/2" x 11" and see what happens. With that size you would not need a bleed control.
Check your control panel in your computer for you printer. Check the advanced controls and see what your options are for photo settings.
Posted on Jul 30, 2008
  • tnrtt Mar 06, 2011
    create a custom document for the bypass tray. you can manually select margins in properties.
I'm getting random prints from the pc and only print errors with Subsystem Errors. Panasonic dp c264 pcl xl error position 15
try to use another driver to see if the driver is faulty. also, you should try to print with the same driver from another computer.
Aug 21, 2014 | Panasonic DP-C264 Color Copier
Drum reset counter
When the drum is replaced the counter on the DP-C264 automatically resets. If it does not reset then the flag on the back of the drum has been damaged in shipment or during the install of the drum.
Oct 11, 2013 | Panasonic DP-C264 Color Copier
Trying to print a booklet but front and back page comes out upside down? Any suggestions?
in the settings you should have something that says binding/folding postion - change this and should bring it right
Oct 11, 2013 | Panasonic DP-C264 Copier
HOW CAN I CHANGE PAPER SETTING IN PANASONIC DP-C264
It is a little more difficult to explain. If you send an email to LBrown18062@hotmail.com I will send you the manual that has a step-by-step picture guide that will guide you thru this process. Please put "panasonic dp-c264" as the subject.
Jan 31, 2012 | Panasonic DP-C264 Copier
How do I get a meter reading on a DP-C264?
Press Funtion Key. Menu will pop up on display to see counter. Press this key to get color and black and white page counts.
Dec 29, 2009 | Panasonic DP-C264 Copier
Trying to print booklet A4 Pages double sided
Sir what is the problem paper jamming? not printing it?
Dec 09, 2009 | Panasonic DP-C264 Copier
What is the recommended copier maintenance for Panasonic DP-C264?
120K and 240K are the big ones? as for the price call around?
Aug 17, 2009 | Panasonic DP-C264 Copier
Panasonic dp c-264 error e04-34
Fuser code, reset in service mode F9 -06-04, continues to come back new fuser required
Aug 05, 2009 | Panasonic DP-C264 Copier
I miss my manual of Panasonic DP-C264 1 year old; how can I do?
Hello sir; You may go on web side to down load, the address is www.panasonic.com
Mar 15, 2009 | Panasonic DP-C264 Copier
Panasonic DP-C264 Copier Logo
353 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
