Question about Sony Handycam DCR-TRV9 Mini DV Digital Camcorder
Bad video head! How does it get fixed??
What do you mean by "use " Hammer " and fix the Rest of Camera."? Could you please specify your point. Than
  • Randy Good Jul 30, 2008
    Thank you for your input.
  • 10,594 Answers
What is left in camera to got repair it? You dont wanna spend $ and wnat to fix it...how possible? its Video Head is damaged.
Posted on Jul 30, 2008
Turn the key, nothing happens, new battery
check voltage at main fuse box (what car)? and those fuses.
to fix electrical , "nothing" means , bad head lights.
so that very simple system is the most easiest to diagnose.
voltage at the head light fuse, (no) then move back to the engine bay
fuse box for power on all fuses there (large fuses)
at one point you get 12v (HL are hot all the time)
between the last bad point and the good 12v point is the section that is open circuited.
easy huh?
Feb 10, 2013 | Suzuki Cars & Trucks
How do I change the decimal plase on my casio fx300s calculator
If you mean the fx-300ES, press SHIFT MODE 6 then a digit specifying the number of digits you want to the right of the decimal point.
If you mean the fx-300MS, press MODE repeatedly until you get to the "Fix Sci Norm" screen, then press 1 then a digit specifying the number of digits you want to the right of the decimal point.
Jan 30, 2013 | HP 12c Calculator
I can't see the numbers after decimal in TI-30XIIS. how can I fix the problem
Press 2nd [FIX] and then select from the menu a digit specifying the number of places after the decimal point or F specifying floating point.
Dec 01, 2011 | Texas Instruments TI-30 XIIS Calculator
I cannot get one screw out of the drill as I try to disassemble it. Any suggestions? It is the screw in the bottom above where the battery goes
You can take a drill bit around the same diameter as the head of the screw and drill the head out. It will get to a certain point and then break off. once you then seperate the housing you can take needle nose pliers and twist the rest of the screw out.
Aug 09, 2011 | Black & Decker Black and Decker FIRESTORM...
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
My music do not sound right
If you are using head phones, that means the headphones are bad and you need to purchase new ones. The wire leading to the headphones must've been a little torn or liquids might have been droppend on it.If you are not using headphones, then that means your speakers are bad. You will need to see if they can be fixed or if they cannot. What you can try is blowing into them, to see if a littl dust comes out. But, otherwise they are broken. Please rate.
Good Luck, Noob815
Jan 01, 2010 | Audio Players & Recorders
Bands or lines on screen during playback
Hi tlaufer ,
              According to the symptom this problem is related to the VIDEO HEAD, As you earlier try to clean the head but no results, Please open the cassette compartment of your camera (as when you insert the cassette in it) for 30 mins (remains open cassette compartment) Actueally some time due to moisture head get durt.
After 30 mins insert the cassette and play it. Hope it will start work again fine.
      But if no result from the said procedure then there must be a damadge of point of the head, in this condition you have to replace the VIDEO HEAD assembly.
Thanks for using fixya.
May 23, 2009 | JVC GR-D73E Mini DV Digital Camcorder
Bad video head!! How does it get fixed??
Here is an option....use " Hammer " and fix the Rest Of Camera.
Jul 30, 2008 | Sony Handycam DCR-TRV9 Mini DV Digital...
Head-Cleaning Tape not Working
Another post here noted yet another discussion about giving the camera a whack on the side. This is not a good idea but since it fixed it points out that it was unlikely it was something the tape cleaner would fix. This likely means a trip to the repair depot.
Sep 14, 2005 | Sony Handycam DCR-TRV120BT Digital...
Sony Handycam DCR-TRV9 Mini DV Digital Camcorder Logo
69 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
