Question about Dryers
How do I replace the drum belt on a crosley gas dryer model CDG600W?
  • 625 Answers
SOURCE: crosley gas dryer
the pilot should be located in close proximety to the main burner. the ignition may be one of two devices - an electronic spark type ignition or what is called a hot rail glo-bar. the flame detector has a millivolt generator which generates a 750 millivolt current after it detects the pilot flame and gives a signal to the main valve to open.
Posted on Aug 24, 2007
  • 552 Answers
SOURCE: How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Feb 05, 2008
  • 161 Answers
SOURCE: gas dryer not turning
I can explain how to do this but I would suggest going to the library and looking for a generic repair book with diagrams. It's hard to explain but very easy to do. Most Whirlpool, Kenmore and Roper dryers are basically the same as far as belts and moving parts. The only difference is the features. What you neet to know applies to both gas and electric dryers. You should also replace the idler pulley and both rear drum rollers while you are in there. One of these probably caused the belt to break. Your dryer will run so quietly after this you will hardly know it's running You will also need the diagram on the belt package to replace the belt as it is very tricky the first time especially if you haven't seen it in place. Replacing all the parts I mentioned will cost around $20 - $35 and take about an hour. While you have it apart clean out all lint and check vent hoses and outside damper. DO NOT USE FLEXIBLE PLASTIC DUCT PIPE!!!!!!! It is now against most building codes for darn good reason. It's a fire hazard!
Posted on Jun 29, 2008
  • 170 Answers
SOURCE: ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. This can help you figure out what parts you might need and how things go back together. Good luck!
Posted on Jul 14, 2008
  • 8220 Answers
SOURCE: GE Gas DryerDBXR453 /Drum Belt Assembly
Posted on Jan 05, 2010
Crosley heavy duty dryer blows out heat but will not spin
Check the dryer drum drive belt it may be broken or the dryer drum drive motor may have failed
Oct 18, 2016 | Crosley Dryers
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
Installation Tips: Ribs against drum
For Amana all models will look like this
Installation Tips: Ribs face toward drum
For Asko all models will look like this
For Crosley all models will look like this
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 02, 2010 | Dryers
Dryer runs but the drum is not turning - smells like the belt is hot
............ sounds like he belt is slipping / damaged or broken. If you turn the drum by hand, does it spin? If so, is it easier than normal? If so, almost certainly needs a new belt. Get it checked out - a lot of house fires are caused by clothes dryers!
Oct 19, 2013 | Crosley CDE6000 Electric Dryer
My model # cde6505w crosley dryer is heating and turning and runs fine except that it makes a loud noise while it is running. it almost sounds like a metal to metal noise any suggestions
Hi cswsuzy...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Jul 16, 2011 | Crosley Dryers
The dryer works perfectly but is very noisy can we have the technical diagram for the white knight gas tumble dryer please
The problem is likely the rear drum rollers. Here is a link that should help
You can also enter your model # there for diagrams and illustrations of your specific model.
Sep 16, 2010 | Crosley CDG6000 Gas Dryer
How to replace the belt on a crosley electric dryer
If it is a front load machine, you need to remove the front of the machine.
When you do this it will expose the drum and belt
Sep 26, 2009 | Crosley Dryers
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Crosley Dryer won't start
This could be one of several things. There is a switch connected to the belt on the drum and if the belt slips of breaks the dryer wont start. There is also a possibility the timer is worn out
Oct 22, 2017 | Dryers
Crosley dryer
How to replace belt on crosley cdg6000w gas dryer?
Sep 05, 2008 | Crosley CDG6000 Gas Dryer
Dryers Logo
Top Dryers Experts
