Question about Samsung HP-R5072 50 in. Plasma HDTV
Samsung 42" Plasma HDTV cable hookup problem
My son just bought Samsung 42" Plasma HDTV. When trying to hook up to cable outlet, sparks flew. Hook up to DVD player went fine and TV shows DVD's fine. Cable company examined cable connection and said problem must be with TV. Is it the TV? Does he need to return it for another one?
  • dellen40 Jul 30, 2008
    Solution gave ideas of how to double check cable connection problem. I won't know if it solved the problem until tried.
  • Samsung Master
  • 6,487 Answers
There is really a possibility that the TV is bad for what just happen, better replace it since the TV is still new ...
Posted on Jul 30, 2008
  • 2,296 Answers
I would return it but do not mention the sparks as they will say that is not a manufacturers defect but rather a customer's creating that failure.
To plug the next TV make sure that everything is OFF or better disconnected from the AC power from any device before hooking it up to the TV. Is more likely an ESD discharge that cause the sparks and damage the tuner circuitry.
  • 4,234 Answers
There sould not have been sparks. Check the following: Using a voltmeter check between the cable itself and ground. There should not be any reading (anything less than .1V is normal). Check again between the inner hole of the RF connector and the outside part. Again there should be less than .1V. If you read any voltage at the RF connector, the TV is faulty and should be exchanged. If you read voltage at the cable, have teh cable company check again.
Dan
Cable hookup
this television is actually a monitor...hookup can be completed with rca jacks
Jul 05, 2013 | Sylvania 6842PE 42 in. HD-Ready Plasma...
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Dvd hookup problem
youve hook up plugs wrong im asuming youve hook it up using componet plug featuremach colours so same plugs are in same colour holes//oz
Jul 24, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a 42 inch lg plasma,and everytime i hook up my ps3 it says invalid format
ok, have you tried hooking up your PS3 to a different tv and it work? if so, you may have to change the settings in the PS3 to fit the LG tv. or, it may be in the menu options of the tv for a specific channel or setting. reading directions for hookup is a big help too:P
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Vhs hookup to tv
Try hooking up the AV cables, unless it's an older model(1993-1998) then you might require a coaxial cable. After this you simply plug it into the wall outlet, but I would suggest a surge protector for a Hitachi. If that does not work, then it is simply not compatible, but it should work, good luck
Dec 22, 2008 | Hitachi 42HDS69 42 in. Plasma Television
How to Hook up without HD or Cable box
no place to fit the black cable from the wall
Nov 02, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Cable box hookup
The cable has a bad ground and you should contact the cable provider to get things right. The cable can carry AC voltage and if there is a isolation problem it could blow the TV if you try to hook it up.
Apr 30, 2008 | Insignia 37" LCD Flat-Panel HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
165 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
