Brother printer mfc-7420 will not print
LCD SAYS MANUAL FEED, INSERT PAPER, WILL NOT PRINT OR COPY
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Manual feed is a by-pass tray (not the paper tray,)
in this particular model it looks like one of hte slots in the front. put a paper in and see if it grabs it.
you should be able to cancel out the job by pushing stop/cancel?
1-check the tray to make sure the paper size is correct
2-make sure it is set for tray not bypass
Posted on Jul 30, 2008
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
WHY DOES THE MESSAGE MANUAL FEED INSERT PAPER KEEP COMING UP ON MY MFC7420
if you are trying to print something from your PC and machine has NO paper in tray she will ask you for manual feed. Look in your printer driver properties to see what PAPER SOURCE is chosen.
pifonski
Feb 20, 2011 | Brother MFC 7420 All-In-One Laser Printer
I get an error message on my Brother MFC-7420 printer that displays "Unable to print.See your user maual."
SVC manual list that the:
MFC has a mechanical
problem.
-OR-
A foreign object, such as a clip or
ripped paper, is in the MFC.
try the steps on this link:
http://tinyurl.com/4nu6p3d
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
How do you manually feed paper into the machine? I am trying to put label sheets into the machine and it says manually feed... regular print works
There is a slot in the front with two guides that you adjust for the width of the paper. Insert your labels face-up into the slot. Be sure you are using Laser labels. Get the manual online here.
Jan 30, 2011 | Brother MFC 7420 All-In-One Laser Printer
"manual feed insert paper". the machine is stuck with this message brother mfc 7840N
This means at some point the machine was told to copy or print from the manual feed. So you need to put some paper in the manual feed so it will print out and clear the message. You can try turning off the power, sometimes this will clear the message as well.
Aug 25, 2010 | Office Equipment & Supplies
Brother mfc-7420, how do I get off manuel paper feed
Thank you for following me up, I managed to discover that the document I was trying to print was set up for manuel paper feed, other documents subsequently went back to normal after printing the offending document. However is there a setting on the actual printer to control this.
Regards John
Oct 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 Laser All-in One Printer won't print.
Dont bother your self, just reinstall the printer again and let me no when done
Kaggwa Mozeh
Jun 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
you probably had a document that was not using 8.5 x 11 paper or the print settings were the printer to use the manual tray.
thanks adi
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
701 people viewed this question
k24674
jasbo
jasbo
