Usually mobile phones does not work properly in other countries if they are not unlocked properly. For that purpose, you can get your blackberry unlocked from a vendor whose codes work efficiently and are highly reliable. I would recommend to try Blackberry Unlocking Codes with IMEI because they are fast and cost effective and works anywhere around the globe. You can unlock your blackberry torch here.
I think what the blackberry is asking for is the blackberry password.
If you haven't set it, it's blackberry.
But, to correctly unlock the phone for use abroad follow these instructions.
http://forums.crackberry.com/f209/unlocked-9800-everything-works-instructions-513408/
To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM .
How to unlock Nokia E65 by code ?
Unlocking Nokia E65 by code is very simply . It is also safest and non-invasive method of unlocking your phone. Code to unlock Nokia E65 will be receive after entering IMEI number. You can get Your Nokia E65 IMEI number by typing *#06# or after removing the battery. IMEI is also written on the information label as shown in this picture.
To unlock your Nokia phone is needed to provide the IMEI number and select the correct network that phone is currently working.
Selecting the correct network and the country is very important. Choosing wrong network You risk receiving wrong unlock code.
If we have blocked counter we need to enter code or reset counter using USB cable by program below
How to enter Unlock code RESET COUNTER to nokia using USB cable
Code #pw+123456789012345+1# type in the following way:
1. Turn on the phone without sim card
2. Select character # on the keypad
3. Characters p, w, + get by choosing few times STAR *
4. Press # button to approve code
5. Message "SIM restriction OFF" appears, Your phone is now unlocked
WARNING!!!
You have only 3 attempts to enter the code. The last failed attempt will block the counter.
