Question about Samsung LN-S4051D 40 in. LCD Television
Housing Vibration During Certain Frequencies (At Normal Volumes)
I recently had my speakers and main audio board replaced by a Samsung authorized repair center to correct this issue. About a week later, the vibration has returned, mainly noticeable when watching a dvd and only during certain frequencies. My speakers are mounted by what appears to be rubber posts but the speakers are not actually screwed to the housing, they "float" in the housing by design. Would some sort of felt clamshelled between the front and back housing seal correct this? Is this a common problem with LCD TVs? I've heard of the speaker housing itself being wrapped in thin foam?
Any suggestions would be greatly appreciated. I'm not getting anywhere with Samsung or the repair center. I'm under extended warranty, do you suggest I request a refund or exchange?
Thanks.
Dave
  • neal51 Jan 09, 2009
    I, too, have the same Samsung LCD TV and audio vibration problems at certain frequencies. It's intermittent and annoying. Has anyone contacted Samsung Corp. directly about this issue?
  • Anonymous Mar 22, 2009
    I have same vibrating resonance noise coming from the speaker(s), Samsung LCD LE40A756 (European model) on certain frequences music and mostly speach. Volume is not that high. Tried adjusting Equalizer-doesn't realy help. This annoyng noise coming and going.Still looking for a solution :(
Me again. I removed the rear plastic housing of my TV a few weeks ago on a hunch that the resonance frequency of the two speakers were matching that of the plastic rear housing. Yep. Once I removed the plastic housing (about 8 screws), all speaker vibrations ceased. It's been fine ever since. However, I don't particularly care to have the back off of it, although I see no high voltage parts like a yoke, etc. sticking out or within reach. It's also not mounted to a wall and is in a position where folks can't easily get there hands into the back. I'd still write to the CEO of Samsung since this is a wider problem that they should address without charging a tech fee.
Posted on Mar 22, 2009
2 Suggested Answers
  • 41 Answers
SOURCE: Housing Vibration During Certain Frequencies (At Normal Volumes)
Sir
The problem very well could be with the DVD player because the disc is spinning very very fast and it might be causing the vibration thru out the chassis. Is this only with DVD ? You mention mainly DVD so I would like to know can you notice what type of scenes are causing it with TV ? Maeaning bright scenes or dark or something else?
Hope this is of some help. If you still can request that they come again as the problem isn't fixed. They might replace instead of coming again.
Posted on Apr 01, 2009
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
I want to hook two speakers on each terminal (L/R).
The correct way would be to hook only one speaker to the powered outputs and use PRE-OUT outputs to connect separate amplifier (or active speakers).
For 2 speakers to work connected to the same powered output of receiver, their impedance would need to be high enough. Yamaha receivers officially support impedance >= 4 ohm for front speakers. If you would connect 2 different 8 ohm speakers, the combined impedance could be theoreticcaly 4 ohm, but that depends on many parameters. On low volumes it should work, but could overload the receiver if used for louder volumes.
Also note that the impedance is a function of frequency (specific to every speaker), so for different frequencies the power from receiver would be devided differently between the speakers and the sound would not be good.
Sep 22, 2013 | Yamaha RX-V671 7.1 Home Theater Receiver...
Sound gets muffled at certain frequencies. Please Help!
I think that rather than the mixer, that your front speakers may have a limiter built into the high frequncey amp. You may be asking them to do more that they are capable of.
Mar 04, 2017 | Behringer Sx2442fx Eurodesk 24channel...
Poor sound on my plasma bad speakers
It could be the speakers or the main board. The audio circuit is comprised of the main board, speakers and wiring. That's it. I have seen pinched wires cause problems as well as the other components listed above. You can call 1-800-samsung or go to samsung.com to find the nearest authorized service center.
Mar 11, 2010 | Samsung 50 in. Plasma TV
I'm experiencing an audio distortion in my speakers when the sound is above 32. it sounds like a low roaring. how can i remedy this situation?
Check speakers or speakers ok just need replaced main board
Manufacturer Samsung Part Number BN94-00963E BOARD, MAIN ASSY
Sep 23, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Sir
Apr 01, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
Sound vibrates
Test it by moving the bass and treble up and down. If the buzzing seems disappear at lower volumes with little bass and appears from one side only, it is probably a blown speaker on that side.
If the buzzing is apparent even at very low volumes or from both sides, it is probably an audio board issue. I am not certain if your model has a separate audio board or that functionality resides on the main board.
Dec 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung PS42P2S 42" plasma Sound problem
I also have that problem with mines but my HiFi has audio inputs and i use that for my audio and it works .
Defo weird
Aug 01, 2008 | Samsung PS42P2S 42 in. Plasma Television
Samsung
Sounds like your speaker is blown . Is it a stereo? If so you can try switching the balance to the other speaker to see if its only in the one speaker. You can also switch it to mono to see if tat makes a difference. Let me know what you discover and I can help you further.
Jan 23, 2008 | Televison & Video
Samsung LN-S4051D 40 in. LCD Television Logo
355 people viewed this question
Jerry Greenberg
Jerry Greenberg
