Question about Panasonic RX-D20 Cassette/CD Boombox
UO I is displayed even when plugged into A/C
The UO I display appeared when I turned on the unit, even though it was correctly plugged into A/C outlet (I've never had batteries in the unit).
A few times, the unit would power on by itself, but then UO I was displayed anytime I tried to turn on or off or change to CD mode.
Now it doesn't do anything. Just displays UO I.
Is this worth fixing?
Thanks,
Larry S.
    Problem Solver:
  • 5 Answers
Okay try it 2 times and if does not wotk go to a store and try to fix it okay
sign:chickfix
Posted on Oct 16, 2008
I have a Noma Digital Decorating Instant Light Show Timer and I cannot find the instruction sheet on how to use it. It has 19 preprogrammed light shows and the display shows OL and will not let me reset...
the manual says each unit has a maximum load of 3 amps (abt 7 one hundred mini light sets). when ANY INDIVIDUAL outlet is overloaded,ALL lights will turn off and an outlet overload message (OL) will be displayed. To reset,unplug unit,then unplug some of the lights in the outlet that appears to be overloaded and plug unit back in
Dec 02, 2011 | Hardware & Accessories
Aspire 5570 laptop won't turn on. even if the battery is intact.
If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected.
1. Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings.
2. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet.
3. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary.
4. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover.
5. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced.
6. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too.
7. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws.
I hope you find it very helpful. Thank you for using fixya.
Aug 13, 2011 | Acer Aspire 5500 5570-2609 Laptop
Complete ink failure even with new cartridges
The ink system failure message has a chance to be fixed or it may be a permanent issue. It
can be pointing toward a firmware failure in the printer and if that is the case the
following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration
Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to
“Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared.
Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the
“Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall
outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER”
followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK
INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the
initialization process is complete, the printer will print out a Diagnostic Page.
Good Luck!
Apr 21, 2010 | HP Photosmart 3210 Printer
My inspiron mini 10 wont turn on and it is plugged in. How do I turn it on? the power key does nothing
step 1
  • Step 2 Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet.
  • Step 3 Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary.
  • Step 4 Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover.
  • Step 5 Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced.
  • Mar 23, 2010 | Computers & Internet
    Error 0xc18a0001
    The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold print photo's and the red eye removal buttons then press red eye removal then print photos then red eye removal again. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
    Jan 21, 2010 | HP Photosmart C6280 Printer
    My DVD Recorder & VCR (DRC8320N) has Hello on display
    Even though the power light may be off the unit is still on. It will be warm on top. Unplug the unit for 30 minutes and plug it back in, that will usually reset it.
    Dec 03, 2009 | RCA DRC8320 DVD Recorder/VCR
    46462 unit will not turn on
    Hello anava214
    Welcome
    You said, your washer will not power up . Even the lights on the display panel are not turning on . And you have checked that the power outlet works.
    Did you unplug the washer for 5 minutes and then plug it back in?
    This can resets the system.
    How old is the washer?
    Oct 05, 2008 | Kenmore 46462 Front Load Washer
    GE JCB909 Range - Blank display
    suspect wrongly wired from new
    Jun 25, 2008 | GE Ovens
    Clock display board
    Replacing capacitor C3 on the clock board will correct the dimming problem. I will cost you about $2 for the part. Replacing the board does the same thing just with a higher price tag. Unfortunately, tt sounds like you may have a bad "new" board if this problem happened as soon as you put it in.
    When I had the dim display problem with mine, the oven still heated up, chimed at temp, etc -- you just couldn't see the numbers. My wife didn't like it, so I fixed it. If your old board works like mine did even though the display is dark, you could try replacing the noted capacitor and see what happens.
    I hope this helps.
    Apr 11, 2008 | Jenn-Air SCE30600 Slide-In Electric...
    Panasonic RX-D20 Cassette/CD Boombox Logo
    108 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
