Question about Cuisinart DLC-5 Food Processor
Food processor modle FP155OS, motor turn, but blade doen't, how to disassemble and replace part
  • 24 Answers
Cont -23051554 / 23095757
UNIQUE SERVICES
MUMBAI--400008
Posted on Jul 31, 2008
My food processor blade keeps popping up (loose) when I put food into it.
You will probably need to replace the sleeve on the motor shaft and the blade. If overloaded the shaft can spin inside the blade which wrecks the connection between them. Replacing both together is the correct solution.
May 16, 2014 | KitchenAid Chefs Chopper KFC3100 3 Cups...
I have used my 10 cup processor one time and now when I turn it on , you hear the motor but the blade doesn't turn
With the machine UNPLUGGED disassemble and check to see if the drive mechanism is engaged. Could be as simple as a loose screw in the coupling assembly. I no longer have my unit.. I tossed it in the trash and sent Sears a nasty letter.
Aug 17, 2011 | Kenmore 219103 Food Processor
The motor post on my food processor has deteriorated to the point my blades will no longer turn (just sit there)Can I replace that part ?Or is it too hard for an amature fix it upper?Is that post even...
If the motor is running, the problem can be that the motor shaft is spinning inside the drive sleeve. Replace the sleeve. That is more common than a motor failure.
Nov 30, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Light comes on but won't pulse or turn "on."
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Aug 03, 2009 | KitchenAid Food Processors
My kitchenaid processor is not working
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
I have the unit plugged in and the ingredients in the bowl, but it will not pulse...what am i doing wrong?
I am assuming that the unit is not getting any power whatsoever and this is not isolated solely to the pulse function not working.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
May 10, 2009 | KitchenAid KFP740 Food Processor
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
May 09, 2009 | KitchenAid Food Processors
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Cuisinart DLC-5 Food Processor Logo
135 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
