Question about Toshiba Satellite M45-S265 Notebook
Computer Shut off after 20 to 30 seconds
Thought it was the battery, so replace with a new battery and still have the problem. 1) Power the computer on 2) Booted and went to start up screen 3) While loading at start up shut of after 20-30 seconds.
Have you reloaded the HDD. If not backup your data and put the OS or orignal factory load. Corruption in the system file or bad HDD.
Posted on Dec 02, 2008
OK-so our mac computer is roughly 1 yr. old and its worked pretty great for the time we have had it but,one yesterday i turned i tried to get on the computer and it wouldn't turn on so i jiggled the...
The easiest way to resolve this problem should be to reset the SMC - System Management Controller - which deals with how power is distributed to various parts of your Mac, including the fans.
How to reset it depends on what kind of Mac you have, though.
For 'desktop' Macs, including iMac and Mac Pro:
  1. Shut down the computer.
  2. Unplug the computer's power cord.
  3. Wait fifteen seconds.
  4. Attach the computer's power cord.
  5. Wait five seconds, then press the power button to turn on the computer.
If you have a portable with a battery you cannot remove:
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
If you have a portable with a battery you can remove:
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
That should take care of the problem. Good luck!
Jun 13, 2011 | Apple MB871LL/A Mac Desktop
No problem just want to run it to my computer
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | Computers & Internet
Computer just shut down and now it wont start up again! thought it was the battery I bought a new one but it still wont turn on any clues! thanks
First, you would like to take the battery out and press the power button for 30 seconds. Test another Ac adapter with your laptop. Then put the battery out and try to see if it turns. If that is not the issue, try to see if one of the memory chips is damage. Take one out, then take the other one out if you have two chips of ram of course. If this does not solve you might want to take it to a computer shop to test the motherboard. Good luck!!
May 17, 2010 | Twinhead DURABOOK Ruggedized Laptop...
The screen in blank but the computer is on
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 12, 2010 | HP Pavilion dv6000z Notebook
PC suddenly lost power will not restart
Dec 05, 2009 | HP Compaq nx9010
Compaq C500- Will not turn on no lights except for battery LED lit. It was working fine last night. The computer was left on and the battery ran down so it did not shut down correctly. When i push the...
Oct 22, 2009 | HP Compaq Presario C500t Notebook
Nintendo ds lite shut down
I would contact nintendo if you have a warranty. Also try changing the battery or charger on the internet
Dec 03, 2008 | Nintendo DS Lite Console
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Oct 11, 2008 | Dell XPS 200 PC Desktop
Computer dead
CyberPower battery backup units carry a connected equipment guarantee.
Please contact the Claims Department at CyberPower Systems at 877-297-6937.
Aug 20, 2008 | CyberPower 825AVR (cps825avr-sc) UPS...
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
138 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
