Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Netgear router My netgear router is not allowing me to get on line. I have to plug in directly to the modem. I tried re starting by turning off the modem and router and restarting computer. After turing the modem by on and wanting 2min. and then turning on router, then restart computer. No success on the router. The router has the power light on and the wireless light on with the 1 blinking.
  • serra baby
    serra baby May 11, 2010
    hello!
    --have you tried connecting the computer directly to the router to check if its working?
    -- have you also tried upgrading the firmware of the router?
    Novelist:
  • 173 Answers
First I need to know the following infor to provide you some solution to your router problem;
Internet Service Provider:
Modem Brand Name:
Laptop Model Numbe:
Laptop OS:
Posted on Aug 09, 2008
No internet access netgear router
It may be the device you are trying to connect. shut down everything, unplug , remove batteries, plug in the ISP model, allow the self test, plug in the wireless device, allow it to self test, plug in, reboot the device, laptop, desktop, ipad, phone, whatever. You say you can connect using a Ethernet Cable? Just no connection wirelessly?
Apr 06, 2013 | Computers & Internet
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
If I unplug the internet wire from the netgear and plug into the modem the internet works the minute I plug back into the netgear the internet does not work any suggestions
Most likely your router is not configured correctly. you did not indicate which ISP you have but since you can get on line when connected directly to the modem I would assume that one of two things is happening:
your ISP provided a static IP which is in your computer and the the modem is configured as a bridge.
- this option is very unlikely as most IPs are assigned dynamically.
option two your modem is configured as a router and is getting its information assigned dynamically from the ISP. In this case you will need to log into the web interface of your router (typically 192.168.0.1 if not try 192.168.1.1) with login of admin and password for the password.
make sure the WAN interface (Internet interface) is configured for automatic configuration (DHCP)
save the settings in the router.
reconnect the modem to the router and power off the modem first and then the router.
power cycling the modem and router will clear out the arp cache in the modem.
after they power back up you should be able to go back in to the router and verify that the router has obtained an IP from the modem.
Jan 04, 2011 | NetGear RangeMax WPN824 Wireless Router...
Netgear router is not connecting to internet but i can connect if i plug Ethernet directly into computer from modem
Unplug the modem and router for at least two minutes and till all the lights go off . Then plug the modem back in. Then plug the router back in and it should work. Hope this helps :)
Dec 27, 2010 | NetGear WGR614 Wireless Router
It not let me get internet service i unplug it to move from one side of the room to the other and now its not working
You may need to reboot your cable modem before plugging in the router's power cord.
Are you certain that you re-plugged the Ethernet cable from the cable modem into the correct port on your Netgear router?
If plugging your computer directly into the cable modem allows you to go online, then just re-boot the router once all of the ethernet cables are plugged in to the correct places and then power it back on, and you should be okay.
Oct 17, 2010 | NetGear WGR614 Wireless Router
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
My ip address of the router and modem is same ...
first turn off the computer and unplug the power cords to the modem (if its an external modem) and the router. next plug in the modem, wait one minute, plug in the router, wait another minute, and turn on the computer.
Jan 10, 2009 | NetGear WGR614 Wireless Router
ISP blocking my internet connection.
hello!
-- do you know your verizon username and password?
-- what is the operating system of your computer?
-- have you tried connecting your computer directly to the modem to check if you can get online?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings, you need to input your verizon username and password on the router setup page then save the settings.
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 26, 2008 | NetGear WGR614 Wireless Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
96 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
