Question about Apple PowerBook G4 Mac Notebook
Backlight Hi, Well last night I was starting up my mac, and right as the screen came on, it flickered a couple times and went off. You can still see everything, but its just very hard, and I'm on it right now. So if you can help me. I'd greatly appreciate it. Mike
  • peachgroup Oct 07, 2008
    I had a similar problem. I connected to an external monitor and everything worked fine. I replaced the inverter and the lcd cables but still get a white screen. everything else works fine but still a white screen. After replacing things, I noticed too that now the power cable goes orange.
  • Paul Burrows
    Paul Burrows May 11, 2010
    Hi Mike
    First things first. Have you checked your screen brightness settings and energy saving settings? They sometimes drop down to zero. Like putting screen to sleep after 15 seconds ordim for ambient light. If you can see what you are doing take a look there first.
    If that does not help you'll need to plug in an external monitor to see if it;'s the macs LCD. If the external works we'll have to trouble shoot further.
    Novelist:
  • 137 Answers
The problem is fairly common and while you could test the long-shot possibility that it's not the inverter but the actual CCFL "bulb" (a tube really) that produces the light and sits in the bottom of the LCD panel, the chances are that it's a circuitry problem on the logic board. I've never had luck replacing inverters in these computers (though it works like a charm in PCs).
With the symptoms you have though, it might make sense to try the $20 inverter rather than replace the logic board. It's really quite simple. Just follow the instructions on THIS PAGE and select Apple MacBook Pro (even though you have a PowerBook it's almost exactly the same.)
It will walk you through taking the back off and pulling the LCD, but just notice that on Diagram #2 it shows you where the inverter board is. Just take it out, remove the two cables going to it and replace it with a known good one from eBay. It will be a great $20 way to check a cheap solution. After that fails, replace the logic board.
Or, for more fun, find another person with another laptop who doesn't mind you pulling it apart. Almost all 12" laptops will use a similar CCFL, so you can plug your LCD panel into just the two prong CCFL plug (shown in step 3 of the walk through). If you find someone else with a powerbook or iBook I know for certain that your screen's CCFL plug will fit.
So you could do all this or you could find someone on Craigslist to do it for you for a pretty cheap cost. Good Luck.
to peachgroup: if you have a lighted White screen, it is something completely different.
Posted on Oct 14, 2008
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
It started flickering then went black. When powered off and then back on, it will work for a couple of seconds then go black.
Hi!
I think what your monitor is experiencing right now is because of the backlight inverter in your lcd monitor is about to give up...The backlight inverter is a cold cathode light thats responsible for the image in your screen.. if the lights located on the upper and lower edge of the monitor will be busted then what you will see is black screen.. You will need to replace that in your monitor.
However, without the proper skills to do that and proper tools to open the monitor.. it will be risky for the safety of your monitor..
I suggest that you bring your monitor to a credible technician to replace busted backlight or (burned high voltage ballast transformer - supplying current to backlight)
I hope this help..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Green timer light wont go away
Hi.
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Dell Inspiron B130 Notebook
Sony vaio PCG-GRT30P Screen Problem
You could have a defective screen, either a faulty inverter or a CCFL lamp - follow this to determine the fault.
Apr 15, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Laptop screen flickers and goes off .
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 13, 2009 | Sony VAIO VGN-C140G/B Notebook
MacBook Screen Problem
Hi there
If I understand you correctly from start up the screen is dim but does brighten up after time? But now after start up you are getting a flicker how ever a restart solves this.
On the dimming issue. Check your energy saving settings and brightness key is working OK.
The flickering is a bit of a concern.
Just a couple of questions.
Are there any dead spots on the screen? Areas where there are no pixels.
When you tilt the screen forward and backward, does this effect the brightness or flickering?
Paul
Sep 03, 2008 | Apple MacBook Mac Notebook
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Apple PowerBook G4 Mac Notebook Logo
206 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
