Question about Kenmore Freezers
KENMORE FREEZER MODEL #25323024101
THIS IS A COMMERCIAL UPRIGHT FREEZER WE HAVE HAD FOR SEVERAL YEARS. WHENEVER THE POWER GOES OUT OR WE HAVE A POWER SURGE THE ALARM ON THE FREEZER STARTS BEEPING AND A RED LIGHT ON THE FRONT STARTS BLINKING. THERE ARE 3 LIGHTS ON THE FRONT: A QUICK FREEZE (WHICH YOU CAN TURN ON AND OFF), A POWER ON LIGHT AND THE RED ALARM BUTTON. THE PROBLEM IS WE CAN'T REMEMBER HOW TO RESET IT. WE THOUGHT ALL YOU HAD TO DO WAS HOLD IN THE ALARM BUTTON AND IT WOULD RESET, BUT IT'S NOT. ALSO IS THE QUICK FREEZE LIGHT SUPPOSED TO BE ON OR OFF? HELP...
  • bwojcik Nov 28, 2008
    quick freeze light not working when on
3 Suggested Answers
SOURCE: Kenmore commercial standup freezer alarm
Sounds like the temp sensor is bad or intermittant. Check the connections to the display to see if they are loose. If not, the sensor might be bad, causing it to read the wrong temp. The fact that it is jumping around like that points to this kind of problem.
Posted on Feb 11, 2009
  • 103 Answers
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Posted on Jun 12, 2009
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a Kenmore Upright Freezer. I need to
I unplug mine and let it take several days. You break a line or punch a hole in a line and the freezer will be ruined. Just let it thaw out on its own to prevent damage.
Feb 10, 2010 | Freezers
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Apr 04, 2009 | True 23 cu. ft. / 651 liter Commercial...
Problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Feb 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Defaults to 0 deg. temp
I would be more worried about constant power disruptions
Jun 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
192 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
