Battery life Can I install a 9-cell lithium battery into a Dell Inspiron 1420-123B (T5750) laptop? I've looked at reviews and specs and some say either way.
    Genius:
  • 2,028 Answers
As long as the battery is made for that particular bay (Dell uses the same battery and battery bay in many different models) and has the same output rating, the battery will work fine.
Posted on Jul 30, 2008
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
I've a dell inspiron 1521 battery problem
The battery has an internal failure (Most likely a bad cell) While the battery works, the resolution for the LED indication is to replace the battery. Batteries are a consumable item and generally, batteries have a life of 300 to 500 recharge/discharge cycles before replacement is necessary.
Oct 17, 2009 | Dell Computers & Internet
Where I can find a battery for Dell INSPIRON 1525 ?
Dell 9-Cell Battery : Here
Dell 6-Cell Battery : Here
If I was helpful, Kindly do Rate!
Regards,
Waqar.
Sep 03, 2009 | Dell Inspiron 1525 Notebook
BUILT-IN MIC ON DELL
Yes, it does, 'evidence' below.
Specs of the Dell Inspiron e1705 Being Reviewed:
  • Processor: Intel T2500 2.0GHz Core Duo
  • Motherboard Chipset: Intel Calistoga i945GM/PM
  • Hard Drive: 100GB 7200RPM SATA (Hitachi TraveStar)
  • Memory/RAM: 1GB (1,024MB) Dual Channel DDR2 SDRAM (667MHz)
  • Screen: 17.0" UXGA TrueLife (1900 x 1200 pixel resolution glossy screen)
  • Graphics: nVidia GeForce Go 7800 256MB
  • Optical Drive: DVD +/-RW with DL DVD+R write capacity
  • Battery: 9-cell (standard size 6-cell, 9-cell extended life optional)
  • Wireless: Intel PRO/Wireless 3945ABG (802.11 a/b/g)
  • User Input: Touchpad
  • Dimensions: 15.5" x 11.3" x 1.6" (Width x Depth x Height)
  • TV Tuner: Optional external USB TV Tuner with remote control upgrade for $104
  • Weight: 8.1 lbs
  • Ports:
    • 6 USB 2.0 ports
    • IEEE 1394 (FireWire)
    • Digital Video Interface (DVI-D)
    • VGA out (monitor out)
    • S-Video Out
    • RJ-45 (Ethernet LAN)
    • RJ-11 (56-Kbps Modem)
    • Audio line out for headphone/speakers
    • Microphone
  • Slots:
    • 5-in-1 Multi Card Reader (MS, MS Pro, SD, MMC, xD)
    • 1 ExpressCard 54 slot
  • Buttons:
    • Power on/off
    • Volume up/down/mute (3 buttons)
    • Media buttons (play, forward, back, stop)
    • Battery charge test button
    • Battery lock and release
May 03, 2009 | Dell Inspiron E1705 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
