Question about HP LP2065 Monitor
I have an HP LP2065 monitor that I am trying to hook up to a laptop. When the monitor is hooked up it will flash the image on the screen and then go out. When you push the input button on the front of the monitor, the image will flash and then go off. If you change the display settings on the computer, the image will flash and then go off. I have installed what drivers and software from HP.com for the monitor. I have hooked the monitor up to several laptops and it does the same thing on all of them. Thanks for the assistance.
  • HP Master
  • 32,281 Answers
The monitor is faulty, this is confirmed when you connected to several laptops.
The fault could be a faulty inverter board which supplies high voltage to the CCFL lamp for the back lighting. Have a close look at the monitor at a sharp angle, if you see a faint Windows image then it is definitely a back light fault.
For parts, check out these WEB sites.
LCD screens and Inverters
www.lcdparts.net
http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/ http://www.ccflwarehouse.com/
Posted on Mar 05, 2011
SOURCE:
How to remove hinge cover hp lp2065
Please check your model number it is coming up as a 20" monitor!
May 05, 2014 | HP Computers & Internet
Lp2065
if screen black but green light on then is inverter was bad.
if screen black n green light off or amber then check then monitor defective.
Try with different monitor and result the same problem, either the monitor or the video connection.
Apr 01, 2014 | HP LP2065 Monitor
Screen sethi, i am using HP LP2065 LCD with my computer. Now the problem is that color setting of LCD is not good and hence no clear picture and video.Please suggest me what i should do. thanks
try in menu auto adjustment and factory reset......
you can also play with frequency a little and color setup , clock and clock phase in Image control menu, play with it and you will see result... then save it...
Mar 27, 2014 | HP LP2065 Monitor
Lcd vertical lines
Hook a spare monitor to the computer, if okay! the problem is with the HP monitor "LCD panel defective" not cost effective to repair. But if symptoms are the same for both, the video graphics card on the computer is defective, sub a video cord from the computer to the monitor if possible to cover all angles.
Mar 13, 2012 | HP LP2065 Monitor
Laptop hdmi to dvi monitor
Yes that will work fine
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Dec 28, 2011 | HP LP2065 Monitor
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
When screen comes out of screensaver/sleep mode,
It's a bad LCD screen or bad video card. If its a laptop, try to hook an external monitor to the video port in the back and see if it has the same problem. If it is the same problem, then you know its the video card and not the monitor screen. If you have a desktop PC that has this problem, its most likely the video card. First try removing the monitor and trying it on another computer to see if the monitor is bad. If not, then remove and replace your video card and restart. If same problem, replace video card with a new one.
Sep 16, 2009 | Computers & Internet
HP LP2065 AS 2ND MONITOR
Make sure in the control panel under power options you change the settings so the screen doesn't go into sleep mode and make sure the display doesn't turn of. Do this by changing the times to never.
Feb 08, 2009 | HP Computers & Internet
Cracked Monitor
Hi...there,
Well sure, if you don't mind pay double the prices... My advised, give yourself a new monitor, since the holidays is coming... saved you the headached and $$$...
Oct 07, 2008 | HP LP2065 Monitor
HP LP2065 Monitor Logo
381 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
