Question about Evesham Computers & Internet
Serial ref WO01099133 VY1243000817 VOY64 Will not start up - contaiminated system 32\Drivers
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
VY1243000817 VOY64
Will no - spacer.gif How to troubleshoot Windows XP startup problems, Serial ref WO01099133 VY1243000817 VOY64 Will no - spacer.gif src="http://i.fixya.net/uploadSerial ref WO01099133 VY1243000817 VOY64 Will no - spacer.gifpacer.gif" alt="spacer.gif" class="h_mi" /> spacer.gif
splash_icon_quick_poll.gif CHECKLIST ib_right_arrow.gif How to troubleshoot Windows XP startup problems
One of the most common troubleshooting issues in Windows XP is the failure of a system to start up properly. These failures can be caused by a number of issues, including poorly written or malicious software, faulty device drivers, hardware incompatibilities, corrupt or missing system files and incorrect system configurations. Determining the source of the startup problem, and fixing it, is easier if you use a methodical, step-by-step approach.
If the system will not start in Normal Mode or Safe Mode
A Windows XP system that will not start in Normal or Safe Mode is not a good sign and may be the result of corrupt or missing system files, a corrupt registry, hardware drivers or failed services. Your first step is to press F8 during Startup and select the Last Known Good Configuration option from the Windows Advanced Options Menu. If Windows boots normally, check the event logs and hardware manager for clues as to what may have caused the failure. You may also want to check the Add/Remove Programs menu for any new applications that may have contributed to the failure.
If the Last Known Good Configuration fails, the next step is to start the Recovery Console by booting from the Windows XP Startup CD and pressing "R" to repair when the "Welcome to System Setup" screen appears, then press "C" to start the Recovery Console. The Recovery Console is a command line utility that can be used to identify and solve a number of issues in the event that Windows cannot start, including starting and stopping services and drivers. If you receive an error on startup stating that a system file is missing or corrupt, Recovery Console can be used to replace those files as well. For a list of available commands, simply type HELP at the command prompt. For more detailed information about the Recovery Console, check out Microsoft Knowledge Base article 307654.
If you are unable to determine if a driver or service is responsible for the startup failure, you should run the Checkdisk utility from the Recovery Console by typing CHKDSK at the command prompt. This utility scans your hard drive and checks for problems with the disk or file system, which may result in corrupt or missing system files. You should also check the system CMOS and BIOS settings for configuration errors or corrupt data. Note: CMOS and BIOS data corruption can occur as a result of a dead or weak internal battery. Check your motherboard documentation for details.
If you are still unable to determine the cause of startup failure at this point, you have the following options:
  1. Use System Restore to return your critical system files and some program files from a previous restore point. I've had mixed results with System Restore, but at this point, it is still worth a shot. System Restore can be activated from the Recovery Console. The advantage of using System Restore is that your personal files located in My Documents will not be overwritten or deleted. More information can be found in Microsoft Knowledge Base article 306084.
  2. Restore from a backup tape: While this method will recover your system, you will lose any data stored on your workstation that was created after the system was backed up. This method will also not help you identify the root cause of the startup failure, which may occur again.
  3. Perform an in-place upgrade (reinstallation): This process reinstalls the operating system but may result in data loss if not done correctly. The advantage is that it should return the workstation to a bootable state in which important files can be copied. Applications, service packs and system updates may need to be reinstalled for the system to function properly. For more information, see Microsoft Knowledge Base article 315341.
  4. Perform a parallel installation: A parallel installation involves creating a second Windows XP installation on the same workstation, either in a new folder or on a secondary (slaved) hard drive. The advantage of this approach is that it allows data to be recovered on the primary drive, assuming disk failure was not the cause of the startup issue. After any critical data is recovered, the original installation can be restored from backup source and updated with the new files.
Posted on Jul 30, 2008
  • 1,879 Answers
Greetings,
Those files under the System32\Drivers folder are essential for the OS to work properly such as starting-up.
Try using the System/Repair Disk that came with your computer. Perform a "Repair" when asked. Worst, you may need to re-install the OS.
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
    Master:
  • 397 Answers
Do you have your Windows XP installation disk?
Do you know how to enter the system BIOS?
Usb Ports not working
The best solution is to go to ASUS web site and try to download the drivers. You should have to put the model and Operating System that you are using (Ex. Windows 7 32 or 64 bits, Windows 8) and then select the option for USB drivers download them and see if it helps. Also double check the device manager if it has an exclamation mark over the Universal Serial bus Controllers, if there's one that means there's a problem with the drivers. You can check it by clicking on start then right click on Computer and click on Properties then in the right side click on Device Manager.Good luck!
Nov 13, 2013 | ASUS K Computers & Internet
I have a PANASONIC NSDN-W59 MODEL : 08545-00S61 REF : CQ-US0901CJ SERIAL: 76043 in my car and i change my battery now its need a code to unlock it. now what do i do?
Apr 04, 2013 | Panasonic Car Audio & Video
When in reverse chuck will not stay tight. (when removing screws or whatever chuck will loosen and let bit fall out)
I would start out blowing out the chuck with high pressure air because you might have some saw dust or other item causing friction that is allowing the chuck to move. Then I would spray a lot of WD-40 down the chuck to float any contaiminents up.
Jul 06, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Windows vista home premium can't recognize product and won't installI am using F5 theU257 v1 thethe compatible 32 bit for my 64 bit machine. Please Help. Thank You.
Download the appropriate Windows 7 driver from here:
http://en-us-support.belkin.com/app/answers/detail/a_id/3111/~/f5u257-usb-to-serial-adapter---drivers
Use the 64 bit one if you have a 64 bit OS, and a 32 bit one if you use a 32-bit OS.
Or you can download both, start with the 64 bit one. If it is not compatible, the installer will complain and abort.
Apr 12, 2011 | Belkin USB/Serial Portable Adapter...
My 2001 focus just started overheating and im not sure why could you help
there could be a number of reasons
1 if you just toped it up you could have air in the system
2 the cooling fan may not be working
3 the termastat is no longer operating ( they normally fail open )
4 the coolant is old or contaiminated and needs changing
5 a leaking head gasket ( you exhaust will smell sweet and look white in color
6 a blockage in the engine passages the coolant flows
hope that gives you some ideas to look into
Sep 11, 2010 | 2001 Ford Focus
The mechanic says my brake fluid is contaiminated at 52,000... does it need rep[lace?
There may be something other than brake fluid in your master cylinder and brake fluid test strips can detect that. Another way to tell is if the rubber seal in the master cylinder cap is swelling up. Flushing the system for other than contaimination is a good idea to keep your brake system operating more efficiently
Sep 05, 2010 | 2006 Chevrolet Silverado 1500 2WD
I can not find drivers
http://support.gateway.com/support/drivers/dlcenter.asp?cmpid=topnav
This will let you search by your serial number or you can select the drivers from "Browse all Drivers" tab and then select Notebook computers, Model MT3705, and your operating system . Hope this helps, Best Regards, -md
Nov 10, 2009 | Gateway MT3705 Notebook
Computers & Internet Logo
129 people viewed this question
Top Evesham Computers & Internet Experts
Gareth Cockram
Gareth Cockram
CheckitRight
CheckitRight
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
