Question about D-Link DP-301U (790069251979) Print Server
D-Link DP-301U Print Server
I followed all the procedures to setup the print server everything went well until when it ask to locate the printer on the XP list of printers. Since I could not locate my HP OfficeJet 5610 on the list I decided to use the have disk option and I inserted the disk from HP it detected HP instant share as the printer and I continued to install but as it starts to load the files It stops and asks for location of the hpzimc09.dll. I downloaded the latest update from HP for the printer but the same thing happened.
  • rnt-it May 11, 2010
    try and install the printer locally first and make sure it works. that way you will have the drivers on the pc. then try and setup the print server.
    Problem Solver:
  • 9 Answers
Try to do a normal install first. once that works you'll be able to use the driver that is installed to install via the print server.
Posted on Oct 03, 2009
2 Suggested Answers
SOURCE: Unable to setup printer driver fro D-Link DP-301U
I'm not able to install the printer driver Officejet 5610 when conenct to D-Link DP 301U. It always prompt for missing file such as hpzimc09.dll hpzstw09.exe, I'm using the CD proviede when I purchase the printer and also try on the installtion file downlaod from HP website.
Posted on Oct 29, 2008
I am using DP-301U print server and wanting to attach with hp 1020 plus. However the printer in not printing. what is the root cause and give the solution please...
Hello and welcome to fixya.
First off, I would like to provide you a link with the print server's manual to download it directly and have it as spare.
The printer you are trying to install is a laser printer (black/white only) and probably a bit old model.
Therefore, if you are trying to print from your computer over ethernet, and you have windows vista or 7 (64 or 32bit accordingly) you might have the inappropriate drivers for either the print server or the printer. You can find all of the HP printer's drivers HERE. Select carefully based on your OS.
As a SIDENOTE: If you just need the drivers installed and there are only larger setup execut. files available, you can use 7zip or winace to open up the *.exe file and navigate to the appropriate folder and extract only that one to your computer and install the driver(s) from there.
The D-Link DP-301U print server drivers are available HERE. Default username and password for the management console of the print server can be found at pdf manual page 25. The url to access the administration console is dlink-******,where the asterisks stand for the last 6 digits of the print server MAC address.
Overall, not to make things over-complicated (150+ PDF user manual pages) you need to do the following:
1. Install the appropriate drivers of your hp printer on the computer that will have also print serv. softare installed.
2. Install the appropriate software/drivers of the dlink print server on the same computer.
3. Plugin the usb cable of your printer to the print server's USB port.
4. Plugin the ethernet cable of your print server port to the ethernet port of your home router/switch.
5. Setup Fixed IP settings for your print server configuration (page 20 on the manual).
Let me know how that went. I believe you will manage to do it that way quite easily.
**Don't Forget to vote how helpful this was.**
Thanks.
Regards from FixYa.com
Apr 22, 2011 | D-Link DP 301U (DP-301U) Print Server
Printing Problem
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
Print server DL-301U setting
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1006 is NOT in the list):
Apr 14, 2009 | D-Link DP 301U (DP-301U) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
D-LINK PRINT SERVER DP-301U AFTER DOING A SYSTEM RESTORE ON MY DESKTOP COMPUTER (WINDOWS XP) I CAN NO LONGER PRINT TO MY SAMSUNG ML-2010 SERIES PRINTER ... PRINT JOBS ARE IN THE PRINTER QUEUE BUT WON'T...
- Kindly visit this web site for instructions:
http://support.dlink.com/faq/view.asp?prod_id=459&question=DP-100%20/%20%20DP-101P+%20/%20DP-300%20/%20DP-301P+%20/%20%20DP-303%20/%20DP-313%20/%20DP-301U%20/%20DP-311P%20/%20DP-311U%20/%20DP-311U_revB
Mar 12, 2009 | D-Link DP-301U (790069251979) Print Server
Problem with scan from print server
This unit does NOT officially support Samsung printers... but it will allow printing with some. It does NOT support multi-function printers features like scanning for any brand of multi-function printers.
Jan 06, 2009 | D-Link DP 301U (DP-301U) Print Server
Browser Setup Access address for DLink DP-301U Print Server
It's in the quick installation guide, which is freely downloadable from their web site. Top of page #3...
"The factory default IP address of the DP-301U is 192.168.0.10."
Dec 18, 2008 | D-Link DP 301U (DP-301U) Print Server
D-Link DP 301U Print Server not continuous print from vista
Make sure you have byte counting enabled if you are printing through LPR.
Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
D-Link DP-301U Problem
It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
Is this the wireless print server?
What specifically do you mean by PJL printer block?
Aug 04, 2008 | D-Link DP 301U (DP-301U) Print Server
D-Link DP-301U (790069251979) Print Server Logo
766 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
