Hotpoint WD860 Washer / Dryer
Would appreciate any assistance with the following problem: The dryer cycle is not working in the above machine.   Wash cycle   is fine .   The outflow hose does not appear to get warm
indicating that there is no extraction of warm air  What steps can I follow to diagonise where the problem is?
Reagrds
Mustan
Ps copy your replies to mey below email address  Thank you
mustanebrahimjee@gmail.com
Firstly unplug the machine. Take it outside, use petrol + match. Go Currys and buy anything other than a Hotpoint.
All serious apart from the petrol and match, as that could be dangerous.
Posted on Jan 08, 2009
Hotpoint Ultima WD860 Washer Dryer not rinsing properly. Leaves white residue on dark clothes.
quit using powered detergent .we quit many years ago as it does not dissolve properly in our hard water .no problems with liquid .
Oct 16, 2015 | Hotpoint Ultima WF860 Front Load Washer
Ultima WD860 - dryer has been stuck with 1 minute left for about half an hour. Have turned it off but obviously my stuf is stuck inside.
Hi!
Please disconnect your WD860 from the power supply. The door lock uses electrical power to stay closed. After you unplug the machine from electrical power, just wait a couple of minutes and the door lock will be released.
Regards,
Bogdan
Aug 26, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Operating instructions for Hotpoint Ultima WD860 washer/ dryer please
Hi.
Go to the following site for the info you need.
WWW.HOTPOINTSERVICE.CO.UK
In the menu on the left, click on---Hotpoint user manuals.
In the search box on the right, enterr your model number in CAPITAL letters, and without any spaces, then download the instructioins to your hard drive or printer.
Feb 07, 2011 | Washing Machines
How doI get the clips off the Hose
Slide it to the side of the grip teeth this aids removal..
Apr 19, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
