The owner's manual is available as a PDF here: http://www.delonghiusa.com/index.php?product&nid=107 .
Many recommend you plug the heater in and turn it on in a well-ventilated room (like a garage) for the few hours of use. If you are using the heater to warm a room, plug it in with the thermostat set to maximum and set the power selector to 3 until the room reaches the desired temperature. Then rotate the thermostat clockwise until you hear a click. You can set the power level to 1 or 2 to conserve energy while maintaining the current temperature settings.
If you are trying to avoid frozen pipes in an area, plug in the heater and set the power selector to 3 and thermostat to *.
Always remember to keep anything flammable away from the heater (loose drapes etc.) There is an overheating protection circuit built into the unit. To reset it, you need to call the DeLonghi service center.
I hope this helps.
