How to connect the amp,too many inputs and outputs
I really hope u can help me,i have 2 basic speakers with connections in the back for the amp leads to go into,but i am really struggling with what wires i put into the amp and in which connections and then really, really struggling with which connections i need to come out of the amp to go to my speakers.
I have a Carlsbro 150w power module and it has an Output hole of which im guessing is where the speaker connection goes,but on the front of the amp i have 6 channels,each with a hole which is black that says HIGH Z,and also a red hole that says BALANCED LOW Z,and next to it i have two buttons with REV and FX.At the other end of the amp ,ive got another red hole that says REMOTE SWITCH and 2 black holes that say EFFECTS ,SEND and RETURN.Do i need these? I just dont know where to put my output line from my mixer to the amp.PLLLLLLLEEEEEEAAAAASSSSSSEEEE HELP.Im tearing my hair out.
  • vikij Aug 04, 2008
    Duncan,
    You are a star,thankyou soooo much for your help.....youve fixed my problem (problems!!!)
    If i now manage to mix some music together that resembles anything like a dj,(!!!!!!!) i will indeed include you in my royalties when i get paid..lol...Thankyou so much...: )
    A massive hug your way.......Viki xxxxxxxxxxxxxx
    Novelist:
    Champion:
  • 218 Answers
I'll try to help you step by step from your question. My answers will be in all caps. Here we go.
(THIS SOUNDS LIKE A PA AMP AND NOT A CONSUMER STYLE AMP, IS THAT TRUE?)
(IF IT IS LABELED OUTPUT THEN IT IS INDEED A SPEAKER OUTPUT CONNECTION)
( THESES ARE MICROPHONE AND OR GUITAR INPUT JACKS AND MOST OFTEN YOU WOULD USE THE HIGH Z (meaning impedence) INPUT FOR A MICROPHONE
THESE ARE FOR REVERB AND EFFECTS CONTROLS OR INPUTS. YOU DON'T NEED THESE FOR JUST A VERY BASIC SETUP.
DISREGARD REMOTE CONTROL SWITCH JACK
DISREGARD THESE TOO
IT WILL GO INTO THE BALANCED LOW Z INPUT, BUT IT MAY ACTUALLY BE TOO HOT A SIGNAL(signal strength too high), LOOK FOR SOMETHING LIKE A TAPE INPUT OR SOMETHING LIKE THAT ON YOUR FRONT PANEL. IF YOU DON'T HAVE ANYTHING LIKE THAT THEN YOU MAY NEED TO USE AN ADAPTER DEVICE THAT WILL KNOCK DOWN YOUR SIGNAL STRENGTH TO THE RIGHT LEVEL FOR A MICROPHONE INPUT AND THEN PLUG IT INTO THE BALANCED LOW Z INPUT.
HOPE THIS HELPS. GOOD LUCK
Posted on Jul 31, 2008
  • 2,071 Answers
What does the input on the back of the speaker for
Basic speakers only have a positive and negative INPUT that connect to the speaker positive and negative OUTPUTS on your amplifier. These are usually colour coded for ease of identification. If you get them 'back to front' the speaker will still work and your amp will not be damaged but the sound will be down graded. Hope this helps.
Mar 10, 2015 | Audio Players & Recorders
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
I have a velodyne sub woofer needs amp power source I have a kenwood eq and a sony reciever trying to figure out how to hook it all up right
So, you don't have a powered Velodyne sub (with a built in amp?)
Without model numbers - I"ll guess that there are speaker in and out connections on the back of the sub.
You simply connect the left and right speaker wires from the receivers to the subwoofers input speaker wire connections.
Then connect your main speakers from the sub's Out (or "speaker"} connections so that the sub is in line with the speaker path.
Use the sub's crossover settings on the back till you hca a seamless blend of the sub to the speakers where it is hard to tell you have a sub other than you your music now has deeper bass.
Why do you need the Kenwood EQ? This is not a necessary piece as nobody really knows how to use it properly and it realy complicates how you use your system. Flashing lights look cool though, right?
If you really must complicate the operation of your system then connect the Tape output of your receiver to the tape input of the Kenwood EQ, Then connect the Tape output of the Kenwood EQ to the Tape input of your receiver - assuming your receiver even has tape ins and outs.
You can engage the Kenwood EQ by inserting it into the audio path when you select the appropriate Tape input as the source on your receiver.
Hope this helps.
May 31, 2014 | Audio Players & Recorders
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
I don't have any instructions so i don't know how to hook up my speakers and the t.v for surround sound i have a carver avr 100
You should be able to online to the manufacturer of your products and download manuals. However, I will try to help.
Connect the sound output cables from your DVD player including, left/right(white/red) as well as the Coax output/input if your DVD and your Carver each have this feature for enhanced sound on certain DVDs, and connect to the matching DVD inputs on your Carver.
Then, connect your DVD video output either by use of your RGB(RED/GREEN/BLUE cables or an S Video cable to your the matching video inputs on your t.v.
On the back of your Carver, you will find outputs for left and right speakers, connect to the left and right speakers with proper wire. Make sure that the 2 conductor wire is connected with the same side(polarity) on all speakers for the best sound quality.
You will also find rear channel left and right outputs on your amp, connect those to your rear right and left speakers.
Connect the center channel speaker to the center channel speaker output on your amp.
If your Amp has a sub-woofer output and you have a subwoofer, make the connections on that as well.
Test all of the speakers with a feature that many amps have on the menu using your remote, simply called test. if all speakers are connected correctly you will be able to hear each one as they are individually tested by the amp. Hope this helps out.
Oct 05, 2009 | Audio Players & Recorders
I wish to know the correct way to connect a Schneider 800w amp Model:spa-9705. What I have is a lead from my deck(marked sub woofer - 1 x red & 1 x black) but at the back of the amp in question it has 4 x...
Hello i_starlin606,
The Schneider SPA-9705 is a 4-channel bridgeable amp. How you intend to use it and what speaker(s) or subwoofer(s) you are connecting to it will determine the appropriate hookup.
If used to drive 4 sets of normal speakers, you would connect your front channels to one set of inputs (usually 1 and 2) and the rear channels to the other set. You would not use the subwoofer outputs coming from the deck.
If used to drive subwoofer(s), you would need two "Y" adapters with a female input side and 2 male outputs. The cables marked "subwoofer" would be plugged into the female "Y" and the male ends would be plugged into the 4 channel inputs on the amp (paired as 1-2 and 3-4). The front and rear preamp outputs on the deck would not be used.
Speaker/subwoofer connections will depend of the number of individual speakers or subs, whether they have single or dual voice coils, and the impedances of the voice coils.
Hope this helps.
May 06, 2009 | Car Audio & Video
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
New to PA systems......
What brands are we talking about my friend?
Oct 09, 2007 | Audio Players & Recorders
555 people viewed this question
 Grubhead
Grubhead
