Question about Tecnik TKL9260 Front Load Washer
BAGGING NOISE WHEN SPINNING
When my washer spins it is making a really loud bagging noice, I have checked inside and nothing seems to be broken so any suggestions please?
  • adegsx11 Oct 22, 2008
    bangs like the hammers of Hades with a load inside on spin.
    Have tried repositioning load /removinf items with no change
    Empty it spins up fine with no noise.....
    Does this sound like a bearing ? the unit is built in so a pain to try and get to....
  • chrisinclove Feb 15, 2009
    We have the same problem wether it is a small load or large load. the whole machine bags and vibratates alarmingly, is it the springs and shock absorbers that support the drum that are shot?
Hi...
I have a TKL9260 - 7 years old
The machine washes, drains but will ot spin, although the motor is still working - you can hear it.
I'm not an engineer, but have just had the back off my machine and the belt has come off.
The belt has stripped down into strands and wrapped around the motor wheel....so it looks like the strands jammed the wheel and pulled the belt off.
Make sure you unplug from the mains and drain and switch off water supplies.
Gotta find a belt now... :)
Hope this helps.
Posted on Oct 05, 2008
Try moving the clothes around it might be an unbalanced load.
Posted on Sep 03, 2008
When spinning on highest spin make very loud noise like brick inside then heard loud bang and noise stopped washer carried on spinning
Hello that sounds like a broken spider that's blotted to the drum what hold the drum to the bearings if one is broken that will do that the banging is when it pop out on a spin it sounds like a brick hitting the back I would be very carefull as it can try and flip the machine if it catch the drum it's not bearings as you said it stopes and it was ok so it's the spider and most drums are sealed units so you can't do any thing ok hope this has helped you
Nov 13, 2015 | Washing Machines
Washer not working
The spinner's belt might be loose or broken, that's why it doesn't spin... Open the back part and you'll see inside the belt and the motor that makes the noise.
post me results...
Feb 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
My Performa Top Load Heavy duty (PAV1000AWW) has a loud noice when it is spinning. Just changed the belt but still extremely loud when spinning...any suggestions>
Thanks for choosing FixYa and welcome to the site. Anytime you have noise while spending, loud thumps and noises, it can almost always be traced back to the drive motor. This is what allows the washer to spin, drain, and agitate. You need to check this out first and check your spin bearing as well. I would say one or the other is the reason for your noise.
Apr 26, 2011 | Maytag Washing Machines
The washer is making a very loud noice and i noticed slight smell of burning during cycle! The drum seems very unstable too! Could this be the drive belt? Is this fixable or am i looking at a new...
Sounds like the main drum bearings have failed.
Spin the drum by hand from inside, if it feels rough, or it is noisy or rumbling, then the bearings habve fauiled.
Probably better to buy a new washer.
Nov 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
Loud clicking during spin cycle = Maytag washer PAVT234AWW
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion....
Jul 19, 2009 | Maytag Performa PAV2200
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Tecnik TKL9260 Front Load Washer Logo
119 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
