Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Off line We are usually able to print from all comouters to our copier, but something happened and it shows at the computer that it is offline. How do I get back on?
  • 57 Answers
The best possible solution is if possible check from the RUI status monitor. Could be a simple thing, like the machine out of paper, toner or something like that.
Posted on Aug 03, 2008
Hp laserjet 4000 printer always saying "off line" and not printing what could be the problem
Please Clarify, does it say offline on the printer itself or on your printer driver. If it says offline on the printer itself, normally pressing the go button should put it online. However, at the age of that printer the buttons could be dirty/worn out, I have had control panels fail quite often as of late. If it is saying offline on the computer driver then that is a whole different set of issues and I would need to know what operating system you are running.
Jul 20, 2014 | HP LaserJet 4000 Printer
Printer reading offline
The printer connects via a radio link which may have a weak signal, or the card may fail. It could be the computer which has lost the connection. Try closing down the computer, then re-booting. If the printer is soe distance away, try moving it closer.
Feb 25, 2014 | Canon PIXMA MX340 Wireless Office...
Brother HL-2270DW printer shows offline and won't print
I had this problem today with my wireless Brother MFC-990CW using Windows 7, and when I went to see what s printing, then printer, it wasn t showing that I had checked the use printer off-line
So, on my pc I went to the start button then chose:
- Computer
- Network
- Double click your printer
- New print drivers will start to install
- Right click the icon that is a copy made of your printer setup
- Set this as your default printer
I was then able to print and my printer didn t show as being off-line anymore. This is a lot easier than having to uninstall and install the printer again using the disc.
Jun 27, 2012 | Brother HL-2040 Laser Printer
Unable to print from computer, nothing happens when i click print, yet printer will print from scanner. it is a h.p.psc1300 all in one.when i go into the printer on computer it says printer offline error...
I'm assuming it's USB and it got unplugged or turned off recently. Unplug the printer's USB cable for a bit (20 seconds), then plug it back in. Most likely the computer will recognize the new hardware and begin the software install that's needed. When you look at Printer on the computer again, you'll probably see a new one, but it'll show ONLINE. Make this one your default and delete the one that shows OFFLINE
I've had this happen to me several times and the above solution works for me. Good luck.
Jul 27, 2010 | HP Office Equipment & Supplies
Printer remains offline
This could be related to what is call the printer spooler service its possibly disabled
If it is disabled the printer will print work and will show as off line I would check to make sure this service is running. Otherwise please clarify the answer of what happens when you have done the following
Check your connections make sure they are good. Firmly in the computer
Go to Control Panel> Administrative Tools> Services and run your eye down the list and when you come across Print Spooler make sure the Startup Type is Automatic and the Status is running. If not enable it by right clicking on Startup Type then Restart and do the same for the Status field, it should be running.
I hope this helps you.
Please Rate :)
Thank you
Aug 22, 2009 | Brother MFC 7840W Printer
Brother mfc490cw printer show offline and erro
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Aug 06, 2009 | Office Equipment & Supplies
Hp 5400 printer continuously shows as offline
If you are one a Mac, I may be able to help, as this happens to me. Sometimes when I send a print job, the printer shows as offline. HP recommends turning the printer off and then back on, but this did not always correct the problem. Go the the Printer Queue, click on the print job and then click on Pause Printer. Count to 10, then click on Resume. This fixes the problem for me and the printer then prints the job. I am running OS X 10.5.7. This same problem occurred using OSX 10.4.x
May 29, 2009 | HP Officejet Pro K5400n - - colour -...
Printer is offline the hole office they can't print can your please help guys please
Is there an Ethernet cable plugged directly into it or does it connect to a computer?
Does the printer show ON-LINE or OFF-LINE on the display?
Oct 14, 2008 | HP LaserJet 2100 Printer
My printer won't print
Usually you can click on the printer icon and it will show an off line. You can click it to go one line. If that doesn't work for you you may be able to go to document and it may let you click on line. If all else fails reinstall yor softwre. That's what I had to do.
Aug 21, 2008 | HP PSC 1610v All-in-One Printer
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
43 people viewed this question
old marine
old marine
