Question about HP Computers & Internet
I have got a new moderd and a old hard disk drive. when i but the computer on it say i need to chane my settins. thanku diane
  • SALMAN NASEER May 11, 2010
    dear what does moderd mean? are u talking about modem or monitor.
    clear it to me so that i could answer u?
    Genius:
  • 1,011 Answers
Dear,
all monitor has its on settings. u have to do its setting by doing this,
right click on destop and select properties--->display properties---monitor--->properties--->update driver and then select for it a driver by searching or Cd.
regards,
Posted on Jul 31, 2008
Monitor and a oldhard drive. when i but my monitor it say u need the new settings
Posted on Jul 30, 2008
I got a new monitor. and old hard drive. when i but on the monitor it say i got have new settins. thanku diane
Head is stuck or i think it is dead
You may be able to get the data off of it. You'll need another computer with an IDE port and a hard disk big enough to take any data that you may be able to recover off of your old drive -- hook your dead hard disk up to it as slave ( you can see how to configure your drive as slave here )
Put the old disk in the freezer overnight and then put an ice pack on it (put a towel in between so it doesn't condensate and get the hard disk wet) to keep it cool while you try to get the data off of it.
Be sure NOT to touch the circuit board that is on the bottom of the old hard disk to anything metal or you might short it out. If the computer recognizes the old hard disk; you're in luck, copy the data off to the new computer's internal hard disk as fast as you can; your old drive may die completely at any time.
Apr 09, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Change wep password for a motorola sbg900
you can chane the wep key or network key by simply accessin the router paGe and on the wireless settin chane the wep key with your desired passowrd
to access the router just key in 192.168.100.1 on the address bar
the default usename: username and the password: motorola
wireless settins is located on the left of the paGe
Jul 24, 2010 | Arris SURFboard SBG900 Wireless Router...
I have an older dell computer and teh hard disk is
No the O.S. will not still be n the system. You will have to reload it. If you have the original disk, that is. Also take ALL of the pertinent info. you want and load to a disk. Such as, pictures, documents, all downloads you have put in the system including the setup. If you don't know how,email me and I can help. Otherwise,insert a blank C.D.,wait for auto play, select the programs, and or pic. or doc.s. right click and choose send to unless you have the option of "burn to" then use that one. I hoped this helps.
Jul 20, 2010 | Dell Dimension 2400 PC Desktop
How do you transfer hard drive from old comp. to new?
For just the data, get an ide to usb converter and connect it to the new computer, and just drag and drop.
You cant move an entire hard drive to a new computer because of driver issues, but you can use windows built in files and settings transfer utility.
IDE to USB: http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002
Dec 30, 2009 | Gateway 700 XL PC Desktop
Hitachi DK23BA 15 GB Hard Drive
You do not state so, but I believe this is a notebook HD. Your computer manual (probably available online if you lost yours) should give some hints as to how to remove the HD. With battery removed and no power, open the cover, remove the drive and plug in the new one. Then you must boot from the operating system CD, and install on the new drive. Then load all your old software. There are ways to clone your new drive to match the old one (take up where you left off, only with a larger drive), but it is a bit too complex to cover here.
Nov 02, 2009 | Hitachi DK23BA (DK23BA15) 15 GB Hard Drive
Got message 10008 replace hard disk.
Your computer's motherboard has queried the disk-drive in your computer as to the "health" of the disk-drive, and the disk-drive is detecting that it is about to FAIL. So, ASAP, copy all your files to an external disk-drive, before the disk-drive DOES fail.
Buy a new disk-drive, attach it, and use something like NORTON GHOST or SYMANTEC PARTITION MAGIC to "clone" your old disk to the new disk-drive.
Then, disconnect and remove the old hard-drive.
Oct 29, 2009 | Computers & Internet
Hard drive problem
It's possible that your computer's motherboard is "old", and it only supports a maximum of 32GB per disk-drive.
Buy a new 80GB or 160GB disk-drive, and copy all your files from the "old" disk to the "new" disk.
Apr 06, 2009 | HP HRD DRV-SEAGATE SAS 72GB 15K 2.5 SINGLE...
2 hard disks
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Aug 29, 2008 | Microsoft Windows XP Professional With...
Istalling windows
La Cie porsche drive not showing up on my computer
is the drive set on slave or master or cable select if this is the case then chane jumper setting toi master if booting with it on secondary ide but if on first ide then slave and if you have got files on these drives move them off then goto disk manager and delet partition then create new partion and sormat drive then set active in manager properties now reboot machine then open my computer to find the new drive hey presto working hdd
Mar 08, 2007 | LaCie (300803) 60 GB Hard Drive
Computers & Internet Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
