Question about Whirlpool Refrigerators
Light went out after 1 month.
Tried to change light bulb. Instructions say squeeze tabs. There is only 1 tab. Went back to Curry's. They looked at their fridge. Only 1 tab and doesnt move. Got it off by yanking cover from the back. We had a go and it worked. Came home and tried ours but doesnt move.
There must be a simple way to remove cover? Light isnt important except we need it to see if the fridge is working. Please help.
  • ajt12 Jul 31, 2008
    You have given me no ;help whatsoever!
We still cant get the cover off but as the fridge is only 1 month old I dont feel I should pay anything. In any case I'm not sure whether your sign means pounds, euros or dollars?
We are getting our son-in-law to come round next week and use brute force. We certainly shant buy any Whirlpool products again!
Posted on Jul 31, 2008
How do I remove the light bulb cover on my Frigidaire Larder Elite RLE 1099A fridge
Look for a screw that holds the lens in place. If nada then small tabs on side of lens click into the wall. Squeeze the sides of the lens and that should free up the lens.
Jun 22, 2016 | Frigidaire Refrigerators
I have a twenty plus year old 18 cu ft model (top freezer style) and the 40 watt light went out. I replaced the light, but new bulb does not work. Is there a reset button??
two possibilities
1)the door switch is defective and not sending power to light socket
2) the small tab in the light socket is not contacting the bulb (the tab contacts the bulb at the bottom of the bulb) i have found that to be the case numberous times and what i have done to fix it is UNPLUG THE REF then have taken a small flatblade screwdriver and bent the tab so it makes better contact with the bulb since the cold temps will over time cause the metal of the tab to deform
Jul 22, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
JUST WANT TO CHANGE THE LIGHT
I am assuming we are talking about a compartment light. Most every brand the light over has lock in tabs that you release with your fingers by GENTLY squeezing the light bulb cover from one side. Only one side will unlatch. The other side is locked and you have to pivot the cover to about a 40 Deg angle to remove it. Grip the socket so it does NOT flex, unscrew the bulb and install the new bulb. To reinstall the cover... tilt it to align the locked tabs and then GENTLY squeeze the cover again to engage the last 2 tabs.
If you need model specific information we need your model number please. The information above should help you accomplish the light bulb change.
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Westinghouse Refrigerators
Need to change the brake light bulb. Behind the velcro door, where are the 2 places to pinch to pull the bulb holder?
With the velcro door open, you now have access to the tray that holds all of the tail light bulbs. There are two tabs on each side of the tray that secure it to the tail light. Carefully reach inside of the tail light and lightly squeeze on the outside of each tab, releasing the tray from the tail light. See pics.
Thanks for using Fixya and please do rate this answer.
Tabs highlighted in red.
Nov 03, 2009 | 2005 Volkswagen Jetta
Side-by-side Refrigerator Door Exterior Light has shortage
the base of light bulbs vary from different manufactures and sometimes they do not seat all the way. unplug your refrig and try to look into the lite socket. you will see a brass tab in the bottom of the socket simply use a small pick or flat tip srew driver and pull the tab down a little bit then reinstall the bulb plug the fridg back up and it should work. thanks peyton
Jan 19, 2009 | Kenmore 53642 / 53644 Side by Side...
How to open the dome light
There is a plastic tab on 2 sides of the clear (opaque) plastic cover. the cover should be squeezed in towards the center of the light, which will allow the plastic tabs to release from the light fixture so u can remove the cover. Squeeze again to re-install. If you have trouble removing this way, very gently insert small flat screwdriver at outside center of lens, pry gently in to see and release tab.
Oct 19, 2008 | 1985 Honda Prelude
Turn signals
Hello I hope I can help with your turnsignals,Your replacement bulb should be number#3057 1.Raise the tailgate.2.Look on the sides where the tail-light is you should see two push in type bolts(fasteners)remove these by prying under the fastener with a large flat srewdriver,they will come out.3.Once those are removed,carefully pull out the whole tail-light lense.On the back you'll see two bulb socket's with tab's on them.Squeeze the tab's and carefully remove the socket,now remove the old bulb then carefully push in the new one.Hope this will take care of your problem be safe and happy out there. Tim
Oct 08, 2008 | 2006 Chrysler Town & Country
Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Dec 05, 2007 | Refrigerators
Magic chef #rb19k-4a refrigerator: bulb replacement
unplug refrigerator look inside light socket youll see a tab in the bottom of the socket bend tab up alittle bit then screw light bulb back in. if this doesnt help then the door switch is bad
Nov 21, 2007 | Refrigerators
Refrigerators Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
