Question about LG 42LC2D 42 in. LCD HDTV
LG 71SA1D - 180cm (71
I have a LG Model 71SA1D-AA here in Australia. I turn the television on and it runs for say 5-10mins and then turns itself off. The front light indicator of which there are several in a vertical layout used to be Green. Now it is Red when the TV is on.
Lamp Model: AS-LS10
Sales No: 71SA1D
Product Code: 71AS1D-AA.AAULLA
    New Friend:
Hi there WebRepOverall ratingThis site has no rating(not enough votes)
I am not sure when you posted this but I have the same model and reading the manual it seems to be the lamp. Please replace the lamp (check the lamp model on the outside of the TV on the right side facing the TV).
Hope this helps
Posted on Nov 21, 2012
  • Ivan Colaco Nov 21, 2012
    Hope this helps
  • 463 Answers
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
Posted on Mar 12, 2009
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
Posted on May 25, 2010
  • 346 Answers
change the power regulator
Posted on Nov 01, 2007
  • 257 Answers
SOURCE: LG 50px4dr plasma tv turns off immediately after
The problem could come from the power supply at the first suspected one. If you have a knowledge of trouble shooting, open the cover then examine if any caps there look poping up. Use your finger touch on the top of caps you will feel it. If not, check all the fuses there then disconnect all the cables from power sup to other boards, except the main board. Check Va and Vs according to the label attached on the back of panel. If the power sup shut down, replace it with a new one. Hope it helps.
Posted on Aug 12, 2009
SOURCE: my lg tv (model number 42LH40) won't turn on
There might be an off on switch under the lower right hand corner of the set. (feel for it) and switch it.
Posted on Feb 13, 2010
How i replace the lamp in a rear projection tv for LG 71SA1D-AA any instruction or picture to help me to replace it. thank you in advance.
Download the manual. Read it. Follow the instructions.
Finding this stuff is not difficult. You should try a bit harder next time.
Product Support
Sep 11, 2014 | LG Televison & Video
Lg tv model 71sa1d doesn't turn on. only the 6 lights in the front turning on one by one , but the screen doesn't turn on. at all.. any idea how to fix that problem? thank you in advance
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jun 26, 2014 | Televison & Video
I have a LG 50PG60UD - AA television that appears to be overheating. TV starts up ok and keeps working without any major issues. A couple of times recently I have unintentionally switched it off and when...
This isn't an easy fix, it sounds like your power supply board is bad or there is a main board problem. I'd suspect a faulty power supply capacitor or heatsink missing, but you have to bring it in to a tech to know for sure.
Apr 10, 2014 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Hi, i changed the lamp on my LG LCoS Projection TV Model 71SA1D. Everything was great for about an hour or so. The lamp warning indicator reappeared and the TV shutdown only to come back on within a minute...
it may be something with the new lamp or the projector overall. try to turn it off, disconnect the power cord, press the power button for about 10 seconds, remove the lamp and reconnect it making sure it is properly installed. then place the cover securely and try to test it again. you may also need to reset the lamp time for it, refer to the manual of your device for the instructions.
Dec 26, 2010 | Televison & Video
I have no sound on two channels only
If you are in Australia and have no sound on GEM and 7-Mate, follow the instructions here, to update the TV's (LG 50PB4D-AA) firmware. Once done you will receive sound on these channels.
Sep 01, 2010 | LG 50PB4D 50 in. Plasma HDTV
Telewest codes for 6/10/09
00 = C2 B5 BE 41 0D 9B C5 7C
01- 6d ea 8e 97 6a aa da 71
Oct 06, 2009 | StarView SV211K 2-port KVM...
Eurovox codes for the 05/10/09
5a 01
updated 05/10/09
c2 b5 be 41 0d 9b c5 7c
8e 80 d7 ef 44 93 02 2b
(okey dokey (~:)
Oct 05, 2009 | Sony Televison & Video
Need codes to tunea universal remote to a "LG50PB4D-AA" plasma tv and an LG 2.1 amplifier,model NW-840AT thankyou.
bro you dont need a code just start the programming normally when it comes time to enter code just hold up on ch button till tv turns off then press the tv button again it should work
Jun 25, 2009 | LG Televison & Video
Set turns itself on and off with no picture nor sound
You have a major problem with this set. Could be the main board, the Y-SUS board, or the power board or some combination of these.
Mar 30, 2009 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
TV turns on by itself
Just change all the buttom (switches) including: volume, channal, power, and menu buttom. That is the only problem
Nov 20, 2007 | RCA D52W15 TV
LG 42LC2D 42 in. LCD HDTV Logo
530 people viewed this question
Computer Repairing
Computer Repairing
