Dishwashers Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Runs but won"t drain.
Anonymous
Level 3:
  • Master 4,399 Answers
  • Posted on Mar 05, 2011
Anonymous
Master
Level 3:
Answers
4399
Questions
Helped
876513
Points
13003
Have you checked your drain yet. At the main bottom of the dishwasher, often, it will get clogged there. Check around the chopper assembly.
Won't drain
  1. Food & debris are blocking the drainage basket (or drain screen) inside the tub, in the far back
  2. Food is clogging the drain hose - the long tube that runs under the sink
Model AE9433 won't heat, says clean lint filter
If every thing is clean you mite need to reset it, unplug it for few minutes.
Dec 16, 2012 • Dryers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 • Dishwashers
Washer won't fill water runs out bottom
either you have a bad drain hose or the drain pump has a bad seal behind the outer case
The rinse cycle won't spin out, it starts but doesn't "spin up" and just runs for ever if you let it.
Possible that the program controller unit is a suspect. So intitially check the inlet valve , check for water flow, if not remove and check INLET valve. after water filling the motor must start, if not the level sensor or the program controller is a suspect. Also if after wash if there is no drain then the drain pump must be checked.
Check the voltage outputs to confirm if the program controller works to the cycle.
My HE2 front loader has a problem draining. It will be "locked" after washing. It is either full of water still, or needs to go through an extra "rinse and spin" cycle to drain the...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely, if the issue returns then it is time for a new pump. Hope this helps... Please post back for any further assistance.
Daniel
THe machine won't rinse. Displaying a "OE" symbol
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
4helpful
2answers
My washer won't spin. It stop and gave me a warning "UE". What is this mean. Please help me.
I have a LG LNC6753A71 the washer agitates drains rinses but won't spin. The motor runs but it won't spin.
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
