Question about NAD Audio Players & Recorders
NAD 330 CD player plays intermittently - NAD Audio Players & Recorders
  • 2,071 Answers
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Jul 31, 2008
Hi, I have a NAD C541i cd player when i turn it on i get three blue line on the display, i open the draw and insert a CD disc but the blue lines stay on the display and the disc don't play. can you...
The blue lines you mention should flash when trying to find
the 'Table of Contents' of your CD, even if a CD isn't loaded.
If when a CD is loaded and these lines flash for a while without
any CD info e.g track no. / disc length then it's more likely that a problem has occurred with the laser.
Various NAD CD players use the Sony KSS-213 Laser unit
and for some reason particularly with NAD CD players, they tend
to drift out of calibration over time so what i usually do when i come across this is very finely adjust the pot trim on the laser itself and testing a CD between adjustments.
Jun 22, 2011 | NAD C541 CD Player
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
NAD CD PLAYER NOT RECOGNISING DISCS
Try this:
1) Disconnect the powercord from the plug!!
2) Remove the cover
3) Reconnect the powercord, turn on the power and press eject.
4) Turn of the power - beware, there is still power on the trafo!!
5) Now you have to carefully clean the laser (round glas-like item in the middle of the drawer) with a cotton swab filled with isopropyl alkohol.
6) Then wait at least 1 minute.
7) Turn the power on again and try to play a cd. If it works as it should then you have succesfully repaired your cd-player :-) Otherwise you may try again.
8) Now disconnect the powercord and replace the cover.
If this doesn't help I'm affraid you have to turn it in to your local shop for further invistigation and repair...
Good luck :-)
Sep 16, 2009 | NAD C521 CD Player
NAD 5355 loader not functioning due to stripped gear
Hi ...
Contact NAD parts thru their website.
or
oaktreent.com might have spare parts.
Mar 12, 2009 | NAD C521 CD Player
Want to play cd on old cd player
If you want an old CD Player to play a disc burnt on a PC, the file format has to me .wav. Most burning software will convert other formats to .wav files.
Feb 20, 2009 | NAD C522 CD Player
Nad cd player cd541i noise
Hi...
That one is going to need Tech service.
I've worked on several of the NAD players.
Sounds like a focus or gain adjust needed.
Feb 14, 2009 | NAD C521 CD Player
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
Sep 06, 2007 | Audio Players & Recorders
Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Aug 14, 2007 | NAD C521 CD Player
101 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
