Question about Windsor SR12 Sensor Bagged Upright Vacuum
Dirt Devil Vibe No Suction
It is a bagless vacume it has very little suction, and the hose has practically NO suction i have bought a new filter and still nothing!! i can' t afford a new vacume how do i fix this?
  • ladyfairybug Jul 31, 2008
    I am going to try this when i get home tonight thank you very much
  • 328 Answers
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Posted on Jul 30, 2008
Why is my Dirt Devil Vacuum Hose lacking suction?
I have a Dyson and was having a similar problem some time back. I found out these bagless systems still have a filter that picks up the fine dust to keep it contained. Find out where yours is located and beat the dust out of it really good or just replace it.
Hope this helps.
Mar 10, 2014 | Dirt Devil Vacuums
My dirt devil breeze shoots out dirt from vent
try cleaning the filters and clear out hoses, sounds like it has backed up inside, also if the filters aren't clean it can loose suction.
Nov 01, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
No suction through top of hose - HELP
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Jul 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Lost suction
TOSS IT and forget it! I have never used a hand vac that worked that was worth the effort of turning it on .... I suggest they are all junk ... I found very few vacuum cleaners ... actually **** especially anything made by dirt devil ... I do have a bagless Bissell 6579-2 that I purchased 4 years ago at walmart for $49 ... It outperforms any vacuum I've ever used, including my worthless Shop-Vac that I paid a lot more for ... this Bissell vac SUCKS ... It could **** the barnacles from a steamship!
Apr 28, 2009 | Dirt Devil Vibe AllPurpose Hand Vacuum...
No Suction ARGH!
on the backside you will see a clear type of hose towards the bottom coming up the back.thats your intake hosethats whats clogged.you will see a connector that its connected to.on the connetor there is a screw,take the screw out and pull the connector away from the cack.take a coat hanger and bend the end so its round and work it down into the intake hose ,you should be able to push the clog out through the bottom.be carefull not to puncture the hose
Mar 15, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Suction
make sure the brush roller is turning.if not the belt ie either broke or it might have come off the motor shaft.feel free to call me at 314-628-9153
Jan 26, 2009 | Dirt Devil Featherlight Bagless Upright...
Windsor SR12 Sensor Bagged Upright Vacuum Logo
1,397 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
