Question about E-Machines eMachines Desktop PC
HELP RE: Replacing Video Card
I thought I was having a monitor issue - display comes and goes (receiving message that cable is disconnected). pc starts up and I can hear it running, but monitor is blank. Had Sony 19" flat screen. So yesterday I bought new Hannspree 19" - same problem. All cables have been checked so now wondering if the video card needs to be replaced. The PC (eMachines T3092) is 4 yrs old. I don't know alot about computers.........how do I know what video card to get? Thank you for assistance!
    Filmmaker:
    Uploaded 5 video answers.
  • 97 Answers
You probably have a built in video card :( those are not replaceable. sometimes you can add one but all you need is a cheap pci graphics card for less than fifty bucks. go to newegg.com to see what they got. good luck
Posted on Jul 31, 2008
My dell optiplex gx 260 has a blank screen when I turn it on. The windows xp professional screen comes up then when it goes to where the desktop should show up all I get is a gray screen
1. From reading your issue it seems the video card is defective.
2. If you have received the Windows XP splash screen and then the monitor displays a gray screen then only two things have happened here your drivers are corrupt for the video card or the video card itself has failed.
3. Suggestion: install a new video card compatible with Windows XP.
4. Most Dell Optiplex desktops have the video graphics card integrated to the the mother board.
Oct 14, 2011 | Dell OptiPlex GX260 PC Desktop
I have a emachines amd athlon 64/ 512mb memory / 160gb hadr drive dessk top. when i turn it on the monitor displays no signal and goes off. ihear the prossessor motor running constantly which normally goes...
Please check the cable that connects the monitor to the video card. Reseat the cable, the issue might be a loose connection. You can also try a known good monitor to isolate if it's the video card or monitor that is causing the problem. Something is preventing the monitor from receiving signals from the video card, hence the "no signal" message.
May 19, 2011 | eMachines Desktop / AMD Athlon Processor /...
Hi, I have a monitor that shows me the red screen, you can see the picture but is at least what is seen and thought may be the vga cable or may be the LCD which is damaged. I await your quick and...
Hi There and Welcome to Fixya,
The first thing you should do is to check if the pins in your VGA cable connector (from the monitor) and make sure if they are "complete and straight" - no bent or missing pins etc. It would be best if you have another PC or Laptop to try your monitor display out so you can determine which is really the problem.
In case you experience the same issue after trying the display out from another PC, then it is evident that there's a need to replace your LCD monitor. Now, if it's the other way around, then it's quite possible that you can resolve this by :
  • Reseating/replacing your video card (if you have one)
  • Updating your video display driver
  • Reinstalling your Operating system.
  • If it's onboard video, then I would suggest to purchase a video card compatible with your motherboard as oppose to replacing the entire board which is much more expensive.
I hope this helps,
Thank you for using Fixya.
Feb 26, 2011 | Northgate 17" LCD Tilt Screen Innovations...
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Nov 04, 2009 | Acer Aspire m5640 PC Desktop
I turn on my pc all fine screen says no signal help please
Verify that the VGA cable is fully seated and connected. If you can test the computer on another monitor or test another computer on that monitor. Are you getting any video display on the monitor? Does it display the start-up screen then goes away when windows starts? If so start the computer and press F5. A menu will come up and select to start computer in VGA mode. This should bring up windows so you can change the screen resoloution to something the monitor can handle. If the computer does not display anything and the monitor is testing good then the on-board video or video card might be faulty. You could change the video card if it has one or add one to the system if it has on-board video. You could also try re-setting the BIOS jumper to clear the cmos or pull out the watch battery for 20 seconds. Another thing to try is to disconnect all hardware...cd-rom, hard drive, floppy drive, and memory dimms and see if it boots up with display. If that works the you will need to re-install each piece of hardware one at a time and re-boot until the problem happens again. Once it does that is your problem device. You could also try swapping out the power supply and see if that is the cause of the problem.
Sep 26, 2009 | HP Computers & Internet
Why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Feb 24, 2009 | Acer X193W LCD Monitor
After many faults my monitor is not receiving signal from my computer
Unplug your VGA cable and Switch on the monitor. It Should display a message that Cable is not plugged in like. If that message comes then monitor is alright. Once again plug and check the VGA cable of your monitor. If it works than its ok. Otherwise there is a problem in your display card which is present in the motherboard. You can insert an new display card or graphic card into your motherboard. Thank you.
Sep 09, 2008 | Computers & Internet
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
E-Machines eMachines Desktop PC Logo
94 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
