The outside unit is running, but the fan will not turn.
  • 182 Answers
Sounds like you need a condenser fan motor.
Posted on Jul 30, 2008
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Why tempstar 5000 High Efficiency a/c outside fan won't turn off ?
Sounds like your contactor is sticking in your outside unit. They could be welded shut.
Jul 21, 2014 | Heating & Cooling
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
Can i run the fan on my inside unit if the outside unit is not working
You should be able to run the fan on the inside unit if the outside one isn't working. If you're worried, turn off the circuit breaker for the outside unit. If you don't know why the outside unit isn't working, check the circuit breaker at the breaker panel, check the breaker inside the box that electrically connects to the outside unit, and check the outside unit for a reset button.
Oct 15, 2009 | Heating & Cooling
OUTSIDE UNIT TURNS ON ,BUT FAN WILL NOT RUN.
bad motor? faulty thermostat? turn fan switch to on still no motor you'll need a volt meter to figure out what is wrong or hire somebody with a meter who can fix it hvac contractor.
Dec 17, 2008 | Goodman CKL36AR36 Air Conditioner
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
