Pls i need to know the possible things to do to get my ipod working. If i check the properties, it does not display the used and available space on the ipod and the file system is RAW instead of the usual FAT32, but the ipod can still power. the only things i can do is to play games and check the settings.......the about in the settings show that i has 9.2Gb unused space in it but i cant use it.
SOURCE: Ipod music is gone, but still says it has stuff on it
If you do this through itunes, it should be okay. The trouble is everytime you want to update your ipod, you will need to connect it with itunes and itunes will need to have your existing library that you created for you ipod to perform a quick and troublefree update.
If you are going to get an external harddrive you will need to re-direct where itunes is saving your music and video files. Because itunes will be using your internal harddrive for the system files (that is where windows is), it will automatically save the music to your internal drive. I suggest reloding an updated version of itunes from http://www.apple.com/itunes/ here and when asked where to install it, redirect it from C:programfiles.......to your external harddrive. This way the itunes music folder will be on your external harddrive.
Hope this helps
SOURCE: i cannot copy mp3 files
I suggest you restore your iPod through iTunes.
Then check for any updates.
SOURCE: My Ipod nanno gen2 4GB screen is no longer showing any displays.
Hi Guys.. try this out
SOURCE: My Apple ipod display screen shows lines (coloured
Sounds like a bad display. You can get replacement displays here http://www.ifixit.com/iPod-Parts/iPod-Nano-Gen-2-Color-Display/IF199-000
-=/ Daft Tech /=-
SOURCE: My Apple ipod display screen not working still plays
http://www.ifixit.com/iPod-Parts/iPod-Nano-2nd-Gen
-=/ Daft Tech /=-
