Question about Frigidaire Kitchen Ranges
F30 fault code on model ples389ecb - Frigidaire Kitchen Ranges
F30 code fault means the temperature probe has an open circuit. It could be the probe or control board but probably not. There is two thermal overload switches in this circuit which may be tripped. One is located in back of range and the other is located in the front near right burner knob. Find these two switches and mash red button on them to see if it clicks and resets. Dana
Posted on Aug 01, 2008
  • boise2625 Apr 14, 2011
    there is no reset button on a ples389ecb electric near the front right burner knob!!
The electric range is a Kenmore model
Bad oven temperature sensor.
Sep 02, 2014 | Kitchen Ranges
I HAVE A F30 ERR DISPLAY ON BOARD AND THE DOOR IS LOCKED. HOW DO I RESET AND GET DOOR OPEN?
Hello Friend, this is Z. I am happy to assist you!
If you are getting an error code F30 on your Frigidaire range, it usually indicates an issue with a faulty sensor probe or a wiring harness between the sensor probe and EOC (Electronic Oven Control). You may try and reset your range by disconnecting the power or by flipping the circuit breaker off and back on after 10 minutes. This often clears most false error code. If the error code does not clear, most likely the EOC of your range will need replacing. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Aug 05, 2014 | Frigidaire Ovens
When I push the Bake or Broil buttons on my kenmore stove it beeps F30. I do not have a self cleaning oven. The gas burners work fine so I know we have a clear line. What can I do?
Log on to the Kenmore website and click on support. Enter your model number and go to troubleshooting. There you should find what your trouble code means. murf427
Oct 24, 2012 | Kitchen Ranges
F30 comes up and the drain basket is empty
F30/31 - Motor Error
If this error occurs then you should try to run the programme again, but a persistent problem will need to be looked at by a professional. A F30/31 error code can indicate a fault with the carbon brushes, drive belt, motor relay or PCB. You can buy spares for your Hotpoint washing machine at many places on the 'net, simply Google for it.
Nov 09, 2010 | Washing Machines
F30 fault - Refridgerator model RF610
this code does not come up . but i don't know your moder or brand . try removing the toe grill and see if tech sheet is there it will tell you what the code is and what to do about it . mm
Oct 24, 2010 | Refrigerators
F20 error
F20 is a door lock problem. Try resetting the breaker. if the code comes back replace the door lock.
The first thing I would check is the door lock switches and the wire harness.
Here are the break down diagrams for the Frigidaire range Model PLES389ECB
Apr 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Fault code of F30 comes on and water goes straight through my WE127E, can you assist? recently replaced the broken drum spring.
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2009 | Washing Machines
MAYTAG MODEL MAH22PDAWW FAULT CODE F30
I have maytag model MAH22PDAWW it doesn't work the display show's ----
Sep 09, 2008 | Maytag Washing Machines
Kitchen Ranges Logo
906 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
