Question about Epson LQ-2180 Dot Matrix Printer
A continous pink light
When i switch on my EPSON LQ2180 printer, the light at the control panel on top of words written Micro Adjust is Pink(continuos) and cannot print a print test page for fonts and pitch
    Novelist:
  • 110 Answers
Please read through these instructions first and then follow the steps below:
1. Please power the printer OFF.
2. Remove the printer cable from the back of the printer and remove all the paper as well.
3. Hold down the "FONT" and "TEAR OFF" buttons and turn the printer on.
4. Continue holding the "FONT" and "TEAR OFF" buttons down for five (5) seconds and then release both at the same time.
5. Power the printer OFF.
6. Reconnect the printer cable.
7. Reinstall paper and ensure the thickness selector is in the correct position and that the path selector is also correct.
Posted on Aug 23, 2008
How reset printer epson lq-2180 to factory
An Epson LQ-2180 is an old dot matrix printer, it cannot be programmed like newer network printers. All it has is a panel in front where you can select a font, the pitch of the font and paper type. There is nothing to reset.
https://files.support.epson.com/pdf/lq2180/lq2180u1.pdf
Feb 19, 2017 | Epson Office Equipment & Supplies
Blinking light
Usually that is a fatal error. It can be caused by anything. I would start by cleaing and oiling the carriage guide shaft and cleanig the encoder strip.OR
If You Still Need Assistance Then Follow US For On : Epson Printer Support
Feb 05, 2014 | Epson LQ-2180 Dot Matrix Printer
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
Lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
its may be heaving problem with the control panel clean replace the buttons or replace the control panel and check it ................
Dec 22, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson LQ2180 Line not printing
heres is a reason and a tips, maybe you are using a driver of your printer, then check it on your control panel in Printer, number 2 is it might the printer head ribbon have a problem... this time you are going to check the printer physically inside... and have some self test print to recognize that the problem in the printer not the computer...
Jun 23, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Jan 09, 2009 | Epson LQ-2180 Dot Matrix Printer
Micro feed locked
Font and pitch hold down and turn on printer at power switch and please rate at least as FixYA
Dec 03, 2007 | Epson DFX-9000 Matrix Printer
PAPERS PRBLEMS ASSOCIATED WITH LQ2180
check paper feed machanism and paper in sensor open your printer and clean the sencer
Oct 02, 2007 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
265 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
