THE MOST common fault of this kind is the spindry went out of ballence and tripped the safty tab at rear of the wash/spin drum under the rear of the lid. if you slide your hand under the cover rim you can pull the wash drum toward you with your left hand to give a little space to view the under side of the lid you should be able to bearly see a tab sticking down or something the drum could bump into if pushed back far enough if this is so then gently flik or pull this tab forward this is a safety cutout switch leaver, close lid and test
other problems could be a bent lid or corroded parts
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
