Question about Baby Gear
Assembling a drop side cot bed
Have bought a Nadia deluxe dropside cot bed (mammas & pappas) and it hasnt any instructions and im really struggling to assemble it.
  • anne801 Oct 06, 2008
    I have been given a Nadia Deluxe drop side cot bed but no instructions. I don't know how to assemble it as a cot.
5 Suggested Answers
SOURCE: Assembly Instructions Durham Cot Bed
Have attached a copy of my instructions
Posted on May 10, 2009
SOURCE: need 2 dropside rods
Have you tried checking with evenflo.com's replacement parts? They don't sell them anymore, but they still have a link for some replacement parts, but you need the model # (it's on the crib itself, on the warning or safety tag).
Posted on May 29, 2009
SOURCE: assembling instructions for cot bed
I'm selling a salisbury cot bed and would like to download a copy of the instruction manual which I no longer have - also need a couple of fixings to be replaced, where I can get some. Thanks.
Posted on Feb 01, 2010
SOURCE: Assembly instructions for Arabella cot/bed
is there any chance you could send me the instructions as i have the same problem
Posted on Jun 02, 2010
ginko
  • 19396 Answers
SOURCE: mamas and papas richmond cot/bed assembly
Hi.
You find instructions for most Mamas and Papas cots clicking here.
Even if your cot is not listed, check the models in the websites and have a look to different models instructions. Most M&P manuals are assembled in the same way.
Regards.
Ginko.
Posted on Oct 07, 2010
I need the assembly instructions for the AFG Nadia 3-in-1 convertible crib
lost instructions and dont know how to change into a toddler bed
Jan 14, 2011 | AFG Nadia Crib
Mamas and papas richmond cot/bed assembly
Hi.
Regards.
Ginko.
Jun 02, 2010 | Mamas and Papas Richmond Crib
Mamas and Papas Savannah cot instructions
u can download the manual from mamma's and pappa's website
Jan 25, 2010 | Mamas and Papas Baby Gear
I have a manual for this cot bed, I can scan it over to you if you still need it.
Jan 06, 2010 | Mamas and Papas Baby Gear
Mamas and Papas Murano cot bed problem
fully dismatle the cot, keep all the bits.. Take the two slatted sides to bits and put the base pieces of wood from these to one side.
pull the headboard and footboard (is that whats its called) apart take the feet from the footboard and add to the headboard (they are now the sole head and foot boards) screw the 4 nuts with blanking plates to the top 4 holes on the new head and footboards
take the two long slatted size bases and screw them to the lower holes on the head and footboard put the base brackets (L shapped screws) into the corners put the cot base onto the L shaped screws done
May 18, 2009 | Baby Gear
Assembling instructions for cot bed
May 16, 2009 | Baby Gear
Mar 10, 2009 | Baby Gear
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Baby Gear Logo
1,681 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Iron
Iron
Are you a Baby Gear Expert? Answer questions, earn points and help others
