My cd disk tray won't go back in - Audio Players & Recorders
  • 2,071 Answers
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Posted on Jul 31, 2008
My Laptop won't boot
Go into BIOS Setup.
In Boot Options set the first boot device to CDROM.
Put the disk in the optical drive tray, close the tray.
Dell what?
What is the model number?
This is found on the bottom of the laptop.
Post back in a Comment.
Apr 04, 2013 | Dell LATITUDE Computers & Internet
RCA RS2664 Stereo wont play CD in any of the trays but seems to try to scan to play.
The laser pickup unit's lens may be dirty or dusty. Just put a lens cleaning disc into the tray, and play it at least three times, by ejecting the disc each time, and reinsert in in to. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. If it dose not help you, the laser pickup unit of your RCA device should be replaced with same type and number. OK.
Jan 25, 2012 | RCA RS2664 Shelf System
Cd is loose inside sytem
yikes! ive had that happen to me once before because i was moving my xbox around a lot and had the disk inside. and when i opened it, the disk didnt come with it. i closed the tray and opened again and the game resetted back into the tray. never again will i move any console with a disk in it again!
Jan 21, 2012 | Microsoft Xbox 360 Console
What do you do when your xbox won't read disks?
The main problem might be a big problem with the disk tray. There might be an faulty wire that has lost connection and if your disk wont event turn on, there might be a problem with the power supply that supplies the cd tray. If the disk opens and closes but doesnt read and wont say tray is in and keeps saying open tray, there might be a small fracture on some of the wires or there is something wrong with the motherboard of the xbox 360. The best way is to buy the warrenty now and send it to the xbox 360.
Jul 27, 2011 | Microsoft Xbox 360 Console
Tray would not come out tray had been sticking ...
just insert pin in front side of the tray there is very small hole just remove the tray and always keep one cd inside in tray .
Hope this helps. Please rate my response.
Have a good day.
May 18, 2010 | Computers & Internet
I put a blank CD into the tray to record. It
If there is a tiny hole somewhere near the tray you need to poke a needle or something like that in there to open the tray.
Dec 02, 2009 | Philips CDR785 3-Disc CD Recorder
Dvd burner won' eject dvd
On the front of the burner there is a pin hole. Take a paperclip and unfold it so it's a point. Stick it in the hole and it should open the tray. This should FixYa!
Jan 27, 2009 | Lite On LDW-401S DVD+RW Burner
Dvd recorder tray won;t stay in,,, even without the cd or dvd
is this the 360 cause i have never heard of a loose tray, try to take it back to where you bought it.
Jan 10, 2009 | Microsoft Xbox 360 Console
53 people viewed this question
