How do I connect a 20X super all write to a Dell Dimension 1100 computer .The pins on the data lead apear to be different and the power lead apears to be missing from the unit I purchased.
  • sharowjohn Jul 30, 2008
    Absolutley spot on.
  • 19,396 Answers
There is no power lead, just a power connector, you need to connect it internally using a SATA IDE cable, some new computer does not have this connection anymore
Posted on Jul 30, 2008
  • Ginko
    Ginko Jul 30, 2008
    Here is SATA connector, some new computer have only SATA not the old parallel IDE:
    Brigadier General:
  • 6,966 Answers
To my understanding, your new Lite-On LH-20A1L 20x Super AllWrite DVD±RW/RAM is a SATA whereas your Dell Dimension 1100 has only DMA/ATA-100 (Ultra) EIDE. it will not work nor the connectors fit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 30, 2008
    Hi again,
    However, there is a way to interconnect but with the use of an adapter. There are versions for SATA to USB and SATA to IDE. Pls reference this page as a start.
  • Louie  Role
    Of course, if you can have it returned/replaced with an IDE version...
Dell dimension 4700 wont power up but has a blinking green light
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
The leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty. Any bad or faulty power or data lead or connection can cause a computer not boot up.
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard Make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs Power and Data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power lead or fan lead can cause you problems computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Feb 08, 2013 | Dell Dimension 4700 PC Desktop
Dell Dimension 8200 computer has started but monitor screen remains black
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
hope this helps
Sep 10, 2012 | Dell Dimension Computers & Internet
Dell eDimension 8200 computer has started but monitor scren remains black
hope this helps
Sep 10, 2012 | Dell Dimension 8200 PC Desktop
After a memory upgrade my dell dimension 3100 frequently shuts down whilst browsing then restarts
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot
hope this helps
Jul 04, 2012 | Dell Dimension 3100 PC Desktop
My computer wont turn on
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
even something as small as a faulty electrical extension or fan lead can cause you problems
check you CPU make sure its securely seated and has thermal grease
hope it helps
Apr 17, 2012 | Dell Dimension E520 PC Desktop
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
Nov 20, 2010 | Dell Dimension 1100 PC Desktop
My screen keeps apearing "Contrast 100"
Check all cords and cables from PC to monitor. Also make sure the graphics card is properly seated into its slot in the motherboard. That is how I would start. If this doesn't help it might be the graphics card or monitor. Need more info.
Dec 29, 2008 | Dell Dimension 2400 PC Desktop
Computer
The Drive you purchased is a SATA interface, the system you have uses Parallal ATA IDE interface.
You need to get a Drive with an IDE interface for that system.
Jul 30, 2008 | Computers & Internet
Setup bois password 4 got
On the motherboard, very close to the battery, there should be several pins with a jumper on two of them. One set may be marked "reset Bios password", or just "Reset", which will discharge the BIOS capacitor.
Remove the battery first, then move the jumper to the Reset pins for a second or so, then move the jumper back to it's original position and replace the battery.
When you power up the computer, the Bios password should now be empty.
If you cannot find these pins, try leaving the battery out and do not turn on the computer (I know this may not be possible) for several days to allow the capacitor to discharge.
FW
Apr 30, 2008 | Dell Dimension 3000 PC Desktop
NTLDR
hi
reinstall winxp
Apr 03, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
49 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
