Question about Watches
My seiko kinetic watch stops working overnight but it is fine whilst wearing it
  • Anonymous Jul 30, 2008
    Yep mine too.
  • Anonymous Mar 06, 2009
    I have exactly the same problem with my approx. 9year old seiko watch. This is despite it indicating to me that it should keep going off wrist for some time..
Further to the previous solution...
Despite Seiko's claims regarding never having to change the 'battery', the power storage unit or ECU in Seiko-speak (not technically a 'battery') does eventually need replacing. From the symptoms you describe, it sounds as if the 'battery' on this watch is on its last legs as it is no longer charging properly. The good news is that it doesn't have to be an expensive job to have it replaced (providing you avoid going through the local jeweller <==> Seiko chain!). There are companies on the Internet who offer a replacement 'battery' service. I've used one in the past and was very satisfied with both the cost and the good service. A Google Search will probably return a choice of several in your country. Btw, if you have had your Seiko Kinetic for a few years, its probably worth paying a bit more and having it overhauled (clean and oil the movement and replace the watertight seals) at the same time.
Posted on Jul 06, 2009
  • 2,071 Answers
The storage capacitor is weak already that is the symptom of near to run out..
hope this may help;
Posted on Jul 31, 2008
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www, can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
My seiko is keeping good time but the second hand jumps two seconds then hesitates for what seems to be a second then skips two seconds again
There are three solutions for this problem, contingent upon the model:
With both instances, this is a power saving / low charge / low battery feature of the timepiece.
1) Is your Seiko watch a Kinetic / Solar model? If so, your watch contains a capacitor. The capacitor may be bad, OR if you have not been wearing it on as regular a basis, wind the watch (Kinetic) vigorously for 5 minutes, and if the second hand returns to normal function, the capacitor is most likely fine. If is is a Solar model, expose it to sunlight for 4-6 hours or incandescent light for 24 hours and see if this resolves the problem.
2) Else: if this is a standard battery operated watch, take your watch to an authorized Seiko repair center, or Certified Master Horologist. Make sure that the Seiko Repair Center is using Seiko batteries, else make sure they are installing Energizer only - these two batteries will not leak in your movement. Avoid other batteries at all cost, many of them will leak and ruin your movement.
3). If these solutions do not work, and you have not had your watch serviced in the last 3 to 5 years, you need to service the movement. See the aforementioned parties to begin the process.
4) If your watch is water resistant, and/or you plan on wearing it in the water, make sure to have your watch water tested by the appropriate aforementioned professional to ensure it will withstand proper dynamic and static pressure at the appropriate depths.
Feb 04, 2011 | Watches
I have a Seiko Premier Kinetic Watch SNP005. The problem is that the date is supposed to change around midnight. Now the date changes around 9-10 in the morning. I have read the manual and the only...
Thank you for contacting FixYa.<br /> You will have to contact Seiko on this one. I would tell you to just change the date to the day before and then forward the time, but I think I would just contact them as it is such a delicate timepiece.<br /> <a href=""></a><br /> Best regards.
Aug 25, 2010 | Seiko Premier Kinetic® Perpetual Watch for...
My Seiko Kinetic winds down in one week after weaking a years and is not recharging to run after one day of wearing.
It sounds like that it is time to replace the capacitor with a new Lithium Ion battery. Send it to Go to this web sight
Dec 29, 2009 | Seiko Kinetic watch
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Sep 24, 2009 | Seiko Kinetic watch
My seiko stops overnight but works during the day
if the watch is solar power it may not be getting enough to last through the night. if it is battery powered it may just be stuck when in certin postion like upside down or somthing
Jun 03, 2009 | Seiko Kinetic watch
Seiko Kinetic Watch model 8D0557
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at
Oct 20, 2008 | Seiko Kinetic watch
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to:
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Watches Logo
745 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
