Kodak PD6000 Printer Dock will not lift and feed paper from paper tray
  • Anonymous Jan 15, 2009
    won't feed paper
  • Karl Batzler
    Karl Batzler Mar 29, 2009
    I have the same problem, but I found that if I "force feed" the paper (guide the paper in and push) I can make the printer print...
  • 1,879 Answers
Greetings,
Here's the link for your products Troubleshooting Guide
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Posted on Jul 30, 2008
Verify that the paper being used is the correct thermal paper and not inkjet 4 x 6. The correct paper should have Kodak XTRALIFE Paper printed on the back side.
Try the troubleshooting steps below and see if it can resolve your issue:
1. Remove the camera from the printer dock.
2. Print a test page. Press and hold the Print and Transfer buttons at the same time until printing begins (5 to 10 seconds), then release the buttons..
Note: If the printer dock prints a test page, please check and delete any corrupted images on the camera.
3. If it thus,
a. Remove the paper tray.
b. Use a lint-free cloth dampened with water and gently wipe the feed rollers to remove any debris build-up.
Note: The feed roller(s) are gray and are located inside the front of the printer dock.
c. Check for water build-up.
d. Reinsert the paper tray to print.
e. When you select to print a self-test page, check that the paper tray lift plate lifts the paper to align with the feed rollers, so the top sheet comes in contact with the feed roller(s).
If the problem continues, please do
1. Remove the paper.
IMPORTANT: Lift the paper by the edges; do not get fingerprints on the coated side.
2. Check that the paper is printer dock paper.
* The words "Kodak Picture Maker Paper" or "Kodak XTRALIFE Paper" should be printed on the back side of the paper.
* Inkjet paper will not work in the printer.
3. Carefully:
a. Fan the paper to remove any static electricity.
b. Insert only 10 to 15 sheets of the paper into the paper tray.
c. Install the paper tray into the printer dock.
4. Make a print.
Posted on Jun 25, 2009
Poor quality printing - cleaned print head, corrected nozzles, replaced cartridges but still only prints half a page. Today it told me to check the USB cable as there was no communication. I checked and...
Instructions Things You'll Need:
  • Small bowl
  • Water
  • Lint-free cloth
  • Tweezers
  • printer paper kit
  1. Turn off the Kodak Printer Dock, if it is on.
  2. Pull the paper tray from the printer.
  3. Check the exposed paper slot for paper fragments and/or jammed sheets of paper in the slot. Use tweezers to remove any paper fragments from the paper slot.
  4. Fill a small bowl with one-half cup of cold water. Wear latex gloves to keep your hands from getting wet.
  5. Dip a lint-free cloth in the bowl of water. Wring out excess water.
  6. Wipe the paper-feed rollers located in the paper sloth with the damp cloth. Turn the rollers with the cloth to remove any caked-on debris from the rollers.
  7. Turn the cloth to a clean side. Continue cleaning the rollers until the debris is gone.
  8. Let the paper-feed rollers air dry.
  9. Remove the paper from the paper tray. Fan the paper to keep the sheets from sticking together.
  10. Reload the paper tray with additional paper from a printer paper kit. Place the new paper below any older paper in the paper tray. Do not load more than 30 sheets of paper.
  11. Reinstall the paper tray. Print a test picture to check the Printer Dock.
Feb 02, 2011 | Kodak ESP 5 Printer
It keeps saying paper jam why? it is not jammed/
Paper jams are reported under two conditions.
1) Paper reaches a sensor and never leaves it.
2) Paper does not reach the sensor in the time allotted.
A simple test is to put a mark on the next page that should be pulled from the paper tray. If the paper is pulled from the tray, you will find it inside the printer. If the paper fails to feed, it will be sitting in the tray where you marked it.
Don
Dec 12, 2009 | Kodak EasyShare Printer Dock Series 3
Paper not feeding not catching on the wheels
-Remove the paper from the paper trays.
-Fan the stack of paper.
-Turn off your printer.
-Remove the power cable of the printer
-Lift the main tray, then remove foreign objects or debris.
-Remove the rear access(back door) cover from your printer, then check for foreign debris the remove it
-Clean the rollers of the printer using a lint-free cloth with small amount of water
-let the rollers dry
-Reinsert the rear access door (back door) cover
-Fan the paper and put it on your paper tray
-Plug the power cable., wait for the printer to initialize
-Do a test Print., If its still not feeding please download your latest Firmware at kodak.com/go/downloads
Now if all the troubleshooting did not solve the issue please call kodak for service and repair Toll Free 1 800 421 6699. GudlucK
Nov 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Load paper message even when paper is installed in paper tray. i have a kodak dock printer 3
you need clean your printer properly some dust particles in paper sensor could cause its malefunctioning
Jul 22, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Kodak easy share printer dock series 3 faults
got same error, took the clear cover off the paper cartridge and kinda' force fed the paper thru. To my surprise...it worked.
Jul 02, 2009 | Kodak Office Equipment & Supplies
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Paper jam
Hi! In you case, you have to put not thick photo paper in your printer.
Mar 20, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Kodak Printer Dock Paper Tray
ok - hubby did the same thing -duh ! but here is the phone number to call and the part number you need to give them - just verify it hasnt changed.
1800 431 7278 part number 5f0478
I was mad at him :)
Jan 10, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
476 people viewed this question
jasbo
jasbo
