Question about Sony Cyber-Shot DSC-S70 Digital Camera
Sont DSC-S70 sometimes i switch on and the battery life indicator doesn't show - or flashes on and off (this is after charging). How can i tell whether i need a new battery? thanks
Da bateri as sira
Posted on Jul 30, 2008
Wat kayn of problem is dat
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
May 14, 2012 | Lenovo IdeaPad Z560 Notebook
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
Jul 23, 2010 | Quickie Wheelchairs Quickie Aspire Power...
My sony dsc-s70 battery will only hold a charge for a short time can this be fix
Might be time for an new battery. I did an google search for battery's for the DSC-S70 and bought 2 for mine, got the memory cards from Ebay.
Jul 12, 2010 | Sony Cyber-Shot DSC-S70 Digital Camera
Short battery life
its not the charger its time for a new battery
Dec 17, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Sony DSC-S70, battery not charging to a full charge
That battery is not good.if the battery have warranty please give back and get new one. after that the problem continues, The charging control ic of the camera may be damaged
Sep 21, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Camcorders that run on 3 AAA bateries, how long do the batteries last????
I assume we're not discussing the Sony DSC-W55 since that doesn't use AAA batteries.
The battery life varies depending both on the camcorder and the type of batteries. In general, lithiums will last longer than alkalines, which will last longer than a single charge on NiMHs. On cameras that give you the option, you'll use less juice shutting off the display and using the viewfinder. Many manuals will give you estimates of battery life, but these are estimates only, the battery life also depends on how YOU use your camcorder.
Dec 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Panasonic lumixDMC-FX7 camera
Could be either. If on switch on again the indicator is full and you get more work done then its a camera fault. If when you switch on again the battery remains flat then this could be the camera fault too the flash capacitor showing signs of distress. On the other hansd the battery could be nearing the end it useful life. How much is a new battery?
Aug 29, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Charging S70 Batteries
Lithium battery is very sensitive to overcharge, so there is a chip inside the battery to take care that for you. You don't need to worry about leaving it overnight.
Sep 11, 2005 | Sony Cyber-Shot DSC-S70 Digital Camera
Sony Cyber-Shot DSC-S70 Digital Camera Logo
83 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
